Howard;
can you please take a couple of pictures of the inside of your 37" genesis?
I gotr oneof Bens 37" Daytona hulls and will be running a 1760KV suppo on either 8 or 10S.
Just waiting on the new HV ESC's he is going to be carrying to arrive.
thanks much
Carl
c.cisneros21@comcast.net
getting ready to launch the twin FE 45" Insane mono conversion on its; maiden voyage next saturday if the weather cooperates here in the N. VA area.
32" hotr 90+mph
This topic is closed.
That outrunner is far from the quality you want for a speed runner. It says only 70 amps max for 20 seconds... not good, Poof!Originally posted by martno1fan View PostVery nice runs,can i ask what setup your using in the Genesis cat.Im in the process of making a plug for a similar type cat based on the mystic cats shes 38" long and im not sure what setup to go with when i get one built,i was considering the Turnigy 3648 1450 kv motor on 4-6 s maybe the t 600 on 6 s .Could also go with twins.
http://www.hobbyking.com/hobbyking/s...idProduct=8485
The Suppo type outrunners that Fightercat sells far surpass those motors. HK also sells some Suppo outrunners.
I like the Turnigy Trackstar 4068, 2560Kv, 6 pole motor, 2200watts.
I have one on the way this week to drop into Miss G for speed runs....
Beauty motor!!!
Leave a comment:
In my genesis and 32 i have the same setup. Leopard 4082 1500kv on 9S and i run a s/f 240HV. I'm not into outrunner motors, I think water cooled is the way to go in a sealed compartment. It all really comes down to fast you want to go. I like 1 motor in a small cat. Its hard to get your setting just right and another motor just adds to it. You might say its double the trouble, not trying to offend anyone. If there is anything i can help you with just ask.Originally posted by Martinson View PostVery nice runs,can i ask what setup your using in the Genesis cat.I'm in the process of making a plug for a similar type cat based on the mystic cats shes 38" long and I'm not sure what setup to go with when i get one built,i was considering the Turnigy 3648 1450 kV motor on 4-6 s maybe the t 600 on 6 s .Could also go with twins.
Leave a comment:
Leave a comment:
I have a vid of my genesis but no gps. Forgot to hit start but looks very fast. Check out the trees blowing around, its a very windy day. http://www.youtube.com/watch?v=
Leave a comment:
Check kintecracing http://kintecracing.com/Nuts___Bolts.html The hatch bolts are short for this setup but t-nuts work good.Originally posted by keithbradley View PostNice.
What are you using for nuts with those hatch screws?
Leave a comment:
I got out for a test run this morning. I thought i would give this new prop a try. I still need to work on it. I'm running the same drive shaft that the motor mount broke loose with (its off balance). I needed to see how this prop handles the top speed before i replace it, i don't want a high speed flip to do the same thing to the new shaft. I have a vid, its not great but ill give you a little something to watch.
Leave a comment:
It is awesome accomplishment and cool that is is like one of our boats that is full scale but I was just thinking it isn't that much power when you can have a 300hp optimax for less money.
Not trying to hate on it.
Leave a comment:
98 mph on the water is impressive to say the least. 131.4hp with instant torque thats the thing that counts the motors torque. what Im most interested in is the esc's they use. most of the electric guys DIY their esc'sOriginally posted by Brushless55 View Post98,000watts = 131.4hp and that is a lot of hp out of a 48volt 15hp motor
700amps at 140volts
Jaked1 youll be happy with 130 hp when u see how much 1 battery cell cost these guys how about 100 plus dollars for one cell. And you talking 140 volts do the math! The price goes up quick for those hungry for electric horses . The battery bank takes up 1/2 the trunk or under the hood around the motor. They typically use 123 cells
Leave a comment:
Garmin Edge 500 bike GPS Unit neutral cycling computerOriginally posted by dasboata View PostHoward can you tell me the model of the garmin you are using and buy the way your boats realy move nice thanks chris
Leave a comment:
Gps
Leave a comment:
98,000watts = 131.4hp and that is a lot of hp out of a 48volt 15hp motorOriginally posted by Jacked1 View PostThat sounds like a lot at first but really is only 130hp.
I would like to make an rc boat from a jet ski hull with that motor! :D
700amps at 140volts
Leave a comment:
Leave a comment:
Leave a comment:
