32" hotr 90+mph
This topic is closed.
  • Howard Lee
    replied
    If you have a strut with smooth sides you will want to take a dremel and cut some small grooves into it. This will help it from moving and change your prop angle.
    Leave a comment:
  • Howard Lee
    replied
    My 32 on the last run started to have a pull to the right on full throttle. I found the stuffing tube had a slight bend. I will do some more testing this week and see if i can make a better vid.
    Leave a comment:
  • Howard Lee
    replied
    I'm working on the 32 it had some problems but its looking good. I wish i didn't try working on the prop i hit a 100 with.
    Leave a comment:
  • TotalPackage
    replied
    Originally posted by FighterCat57 View Post
    I'm working on a tail ring to mount the 1717 air motor in the Genesis mount stock. Just a bolt in. If anyone does machining, mock up a 46.5mm tail ring and see how the 1717 does! I have three ready to test!
    I need to buy one please.
    Whats up Howard what up for today ? You runnin?
    Hey guys why not try your t600 oon 8 or 9 s ? it rated to handle 8 anyway
    Leave a comment:
    replied
    Dang, that's like a Big Block in a VW
    Leave a comment:
  • Jacked1
    replied
    Once again! You are one step ahead!!
    Leave a comment:
  • FighterCat57
    replied
    Originally posted by Jacked1 View Post
    Howard, Have you considered using a castle 1717 on your Genesis to see if you can push it over 100 as well? I have not seen a higher voltage setup with one yet.
    Leave a comment:
  • carlcisneros
    replied
    Thanks Howard.
    will let you know how it goes after next weekend.
    BTW, the pic in my avatar is when it had the CMB 90 in it.
    martno1fan;
    those are the T600 1400KV motors in my twin mono.
    will be on 6S2P
    (2 6S packs hooked up in parallel powering both ESC's.)
    Carl
    Leave a comment:
  • Jacked1
    replied
    I've ran one over 100mph on 9s.
    Not in a boat though
    Sweet! I figured it is pretty close in kv and have handle more amps. Along with being dirt cheap right now.
    Leave a comment:
  • keithbradley
    replied
    Leave a comment:
  • Jacked1
    replied
    Leave a comment:
  • martno1fan
    replied
    That outrunner is far from the quality you want for a speed runner. It says only 70 amps max for 20 seconds... not good, Poof!
    The Suppo type outrunners that Fightercat sells far surpass those motors. HK also sells some Suppo outrunners.
    I like the Turnigy Trackstar 4068, 2560Kv, 6 pole motor, 2200watts.
    I have one on the way this week to drop into Miss G for speed runs....
    Beauty motor!!!
    That trackstar motor looks interesting ,im not looking for record speeds just fast and reliable,i have 2 6s lipos 30c 500mah and a hk 190-200 esc sat doing nothing what speeds would you think i could get with that setup and what prop.
    Leave a comment:
  • 6sHyper
    replied
    Originally posted by martno1fan View Post
    Yea think ill go with the t 600 1100 or 1400 kv motor on 5s 2p maybe 6s which one would be best.Not looking to do 90 mph anywhere over 50-55 would do me.
    http://www.hobbyking.com/hobbyking/s...dProduct=11980
    hey man, my friend here had that same motor in his genesis and it was a slug, it begged for 6s2p and speeds were not very good, 45mph and run times were short. I would NOT suggest that T600 in a single genesis if your looking for speed, but hey if your just looking for a reliable short time runs at 45mph its perfect cause it doesn't get hot at all. keep in mind it needs every bit of 6s though.
    Leave a comment:
  • martno1fan
    replied
    Leave a comment:
  • Howard Lee
    replied
    Originally posted by carlcisneros View Post
    Howard;
    can you please take a couple of pictures of the inside of your 37" genesis?
    I gotr oneof Bens 37" Daytona hulls and will be running a 1760KV suppo on either 8 or 10S.
    Just waiting on the new HV ESC's he is going to be carrying to arrive.
    thanks much
    Carl
    c.cisneros21@comcast.net
    getting ready to launch the twin FE 45" Insane mono conversion on its; maiden voyage next saturday if the weather cooperates here in the N. VA area.
    Very nice setup. My genesis looks like my 32. I don't have any pics but i will take some next time i take it out. I'm going to spent a little time setting up my genesis/37 to see just how fast i can go with a 40 leo. Your build looks good and if you need help just ask.
    Leave a comment:
