Going Insane at RCBOATBUILD
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    #121
    FE 30 P-Sport going up North
    This one is going to be Fasssst !!!
    4S2P / Neu 1515 1Y 2200KV / T-180 V3
    Latest T-180 (V3) needs cooling line re-directed 180 degrees for ESC in front of motor setup
    ESC now has On/Off switch
    Interior
    All that's needed with this color boat are the reindeer !
    • properchopper
      • 7708
      #122
      [ATTACH=CONFIG]126088[/ATTACH] [ATTACH=CONFIG]126089[/ATTACH]
      [ATTACH=CONFIG]126090[/ATTACH]
      Interior
      [ATTACH=CONFIG]126091[/ATTACH]
      [ATTACH=CONFIG]126092[/ATTACH]
      Some outdoor Beauty Shots
        Looks great in the sun Tony (I hear reindeer are afraid of it) hehe.
        • properchopper
          • 7708
          #124
          Thanks Shawn. The gelcoat finish from Insane is gorgeous [until the first race]
          • properchopper
            • 7708
            #125
            .40 Sprintcat for Q Oval and Offshore Competition
            Headed up North to do battle
            Turbine cowl for Nitro isn't FE "tape-down friendly"
            Rear exit trimmed, filled in, deck added along with anodized thumbscrew cowl hold-downs. Speedmaster .60/.90 dual pickup rudder (shortened some) and .250 strut (used with .250 flex stepped to 3/16") :
            Tyler G. modded Schulze 40.160 powering Neu 1527 1Y. Also visible the Mike P. designed in-sponson battery platform lengthened for more battery placement CG leeway. (Batteries are custom made Giant Power/Dinogy 3S 5000 tandems) Motor cooling can waterline fittings upgraded to larger 5mm 90 degree ones and rear entry located to top (to clear motor mount side plate)
            inside/rear with custom motor mount and extended mini-rails for lengthened bonding surface.
            • properchopper
              • 7708
              #126
              NZ Cyberstorm
              Miguel wanted a winning raceboat. NZ rules require no more than 6Kmah on board so we had a TP Power 4040 7D built to spin the moneymaker without eating too many electrons. Patric (Yurkanip) did the hard part & I finished-rigged it by adding some touches of my own.
              NZ rules require a safety loop. I fabbed one out of two ZippKitt radio box bellow seals and a pair of CC 6.5 bullets. Once constructed they just drop in and fasten tightly from beneath
              polished rear hardware
              inside
              • properchopper
                • 7708
                #127
                Three Cheetahs
                "One Flew East, One Flew West, One Flew Over The Cookoo's Nest"
                P-Class : TP 4060 , Swordfish 220A, 4S2P : Clean and simple
                Continued next post :
                • properchopper
                  • 7708
                  #128
                  Another Cheetah
                  TP Power 4060 / Swordfish 220A / 4S2P harness with 6S Adapter
                  4S2P harness :
                  With 6S harness adapter :
                  Snuggling for warmth:
                  • JMSCARD
                    • Mar 2010
                    • 4174
                    #129
                    Dang Tony those Cheetahs look Sweeeeet... love the no nonsense approach!
                    • properchopper
                      • 7708
                      #130
                      Thanks. It all started with this one (now the NAMBA P-Cat 2-Lap Record Holder) :
                        Very nice Tony. I really like the Pursuit.
                        • properchopper
                          • 7708
                          #132
                          Thanks Ray -
                          only :
                            Shaft alignment?
                            What prop is it intended to turn?
                            I really like Aussie rules. In Quebec they do similar setups in GP style hydro's. Lots of passion up there and very industrious. They love the Leopard 3674-2200kv, very efficient.
                            • properchopper
                              • 7708
                              #134
                              Shaft alignment?
                              The motor is just sitting in the boat in this picture, not fastened front or rear.
                              I don't remember what prop
                              I'm very "close" to TP Power and they're very good motors - a step up from Leo as I see it....
                              • properchopper
                                • 7708
                                #135
                                Cyberstorm P-Mono Racer for 2016 FE Nationals
                                On its way North, Customer crossing over to the FE Side
                                TP Power, Swordy ESC
