Going Insane at RCBOATBUILD
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    Here's some builds done for my customers and myself. Enjoy ! [ Need a boat built ? Contact me at rcboatbuild@hotmail.com ]
    First : A quartet of FE 30's
  • properchopper
    • 7708
    Buddy's FE30
    Mello Yellow ( a little bling doesn't hurt)
    • properchopper
      • 7708
      Joe's FE30
      A little prop de-lifting
      Also, notice that my FE30 builds that use T-180's incorporate the right-angle banjo water fittings to allow a 2P battery configuration beside the SC, but also have the motor and SC spaced so that a 1P setup can allow a single battery to fit properly in front as well.
      • properchopper
        • 7708
        Stephen's FE30
        Flyin' the British Flag
        • properchopper
          • 7708
          Kevin's FE30
          The Yellow Rooster !
          • properchopper
            • 7708
            Naveed's Arowana
            Naveed ALWAYS gets a podium finish with this boat
            • properchopper
              • 7708
              Allen's Titan 40
              Allen already had the motor mount fiberglassed in, so I built battery boxes around them and integrated the T-180 mount on them. This'll make a nice P-Mono raceboat.
              • properchopper
                • 7708
                Frank's Delta Force 33
                Frank bought this boat partially completed from an OSE member; the stinger was installed offset to the right - had to move it to to the centerline so the shaft would line up with the rail motor-mount(s). To keep the CG as far back as possible on anything from 4S to 6S I fabbed a vertical mount for the T-180 (a first for me ) but it worked out really nice !
                Non-adhesive velcro firmly attached under the box should keep the batt's well in place.
                ATTACH=CONFIG]56990[/ATTACH]DSC02374-1.JPGDSC02376-1.JPGDSC02370.JPGDSC02365.JPG
                • properchopper
                  • 7708
                  My IB 34" Mono
                  Killer P-Mono Raceboat - Took P-Mono Class Win at H20 Gassers race recently (Actually I only got the win 'cause everyone else lost )
                  • properchopper
                    • 7708
                    My Cyberstorm gets a facelift after the "EVENT"
                    Had first place in the bag, until :
                    • properchopper
                      • 7708
                      My FE30 Tribute to Jimmy Buffett - AAARGGGH
                      Avast Ye Lubbers, Prepare to be Boarded
                      • CHIEFY_44
                        • Nov 2010
                        • 254
                        looks good my friend maybe some more close ups of the insides of some of your builds would look killer on here
                        Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
                        • properchopper
                          • 7708
                          Stephen's IB34
                          Before and After :
                          Got the stinger installed & the rudder backing plate roughed out ( to mount rudder high enough to clear the tabs, the top mounting holes come through above the boat's transom backing plate, so I make a reinforcing piece for extra strength - details, details!). Will shorten stinger, mount the rest of the transom hardware, and start the rails today.
                          • CHIEFY_44
                            • Nov 2010
                            • 254
                            Sounds good tony this is one boat i REALLY want to get wet i mean its such a good looking boat even sitting still in the water.
                            • skellyo
                              • Feb 2010
                              • 596
                              I bought this FE30 from Buddy recently and the build quality is awesome!
                              [ATTACH=CONFIG]56964[/ATTACH][ATTACH=CONFIG]56965[/ATTACH][ATTACH=CONFIG]56966[/ATTACH][ATTACH=CONFIG]56967[/ATTACH]
                              Not sure why the pics don't show up?
