Whiplash Sport 20 Build
The bare hull weighs 4.6 lbs. No hardware installed except motor mount.Last edited by detox; 01-10-2012, 12:31 PM.
Leave a comment:
Look at the differences between these three 8mm x .187 collets.
L to R...Jeff Wohlt 11.15 grams, Octura 33 grams, Kintec 13.80 gramsLast edited by detox; 01-10-2012, 09:09 AM.
Leave a comment:
Your boat looks great just the way it is,
It really came out nice.
I want one now.lol
Leave a comment:
High build urethane primer (Buff color) has been applied and block sanded.
I am using the Zippkits finishing instructions:
Sand the hull. Fill any holes or imperfections with wood filler (microballoons and epoxy). Sand everything with 150. Seal the tub and sponsons with epoxy finishing resin. Be sure that all wood is sealed. Scrape/wipe off as much epoxy as you can. It will make sanding easier. When cured, sand with 150 and recoat with epoxy. This coat will use far less resin than the first. When this cures, wet sand everything with 220. If you are painting, sand the entire boat with 220. Now is the time for primer. Wet sand the primer with 400, and use spot putty to fill any imperfections. Wet sand with 400 and lay on a heavy coat of primer. Wet sand with 600-800 and paint.
I may copy this cool paint scheme. Grim Racer's Yellow Motley Crew development hull.
Hull has been painted using Summitracing's single stage urethane paint (Performance Yellow)Last edited by detox; 01-19-2012, 10:46 AM.
Leave a comment:
I filled the void at taper using epoxy. When epoxy cured I used wood flour and epoxy as filler. Then sanded smooth
I have been using RAKA brand epoxy (350 hardener, 167 resin). Its lots stronger and less brittle than the Z Poxy finishing resin, but takes lots longer to cure. A little cheaper than the Mas brand epoxy also.Attached Files
Leave a comment:
Ridepads widened 1/8" and built up 1/16". Total height and AOA has not been decided yet. I will test different pad heights/angles by temporarily attaching them with 3M spray adhesive. Less AOA than stock may be needed.Attached FilesLast edited by detox; 01-12-2012, 08:56 AM.
Leave a comment:
8s2p anyone? How bout 6s2p? 4s2p?Attached Files
Leave a comment:
I think I will paint hull Yellow and Black, but first I have to build new ridepads.Last edited by detox; 12-20-2011, 08:51 PM.
Leave a comment:
Before cross piece is screwed down. I used a piece of 1/10" carbon fiber plate to brace inside both sponsons. I will predrill using long 1/8" bit so cross piece will not splitAttached FilesLast edited by detox; 01-12-2012, 08:53 AM.
Leave a comment:
just what I was thinking to thanksOriginally posted by detox View PostSeems bracket is the most difficult part to find when mounting a turnfin. Blazermarine does not carry a bracket for the Sport20 fin. So I used 1/2 of strut bracket from this kit. You can call Rossi sales and he will fix you up without buying whole kit. Just tell him it is for a turnfin bracket.http://rossisales.com/
Leave a comment:
After checking for balance I used 8oz of lead in left sponson and 4 oz in right.Attached FilesLast edited by detox; 12-06-2011, 08:42 PM.
Leave a comment:
Seems bracket is the most difficult part to find when mounting a turnfin. Blazermarine does not carry a bracket for the Sport20 fin. So I used 1/2 of strut bracket from this kit. You can call Rossi sales and he will fix you up without buying whole kit. Just tell him it is for a turnfin bracket.http://rossisales.com/Originally posted by HydroMike View PostWhat bracket r u using I have his turn in didn't see a bracket for it might have over looked it guessAttached FilesLast edited by detox; 12-05-2011, 10:19 AM.
Leave a comment:
Leave a comment:
Blazermarine CNC'd Whiplash 20 turnfin installed. This turnfin is on the smaller side, so I installed it deep. Bracket will be drilled again to move fin more forward if need be. Ridepads will be built up and widened later. I am installing all hardware before checking balance.Last edited by detox; 12-04-2011, 06:47 PM.
Leave a comment:
Leave a comment:
