The Voracity tuning thread
  • paulfromtulsa
    • Nov 2013
    • 211
    #286
    That's awesome arrover. Now we need to see some video of the beast
    • arrover
      • May 2015
      • 322
      #287
      Thanks Paul! Hope to get some video soon.
      ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
      • Crash
        • Oct 2015
        • 313
        #288
        Great thread men.
        How much do batteries play in the top speed of these boats.
        I'm getting 46.3 with 5000mah 50 c
        All stock
        • arrover
          • May 2015
          • 322
          #289
          Batteries do play a factor but I would think 50c would be fine. There are some variations in the stock props. Some are faster than others. I would play with your strut depth. I measure my strut depth by the amount that the strut sticks up above the top of the strut bracket. The front of mine is about 1.4mm above and the rear is about 1.9mm above. Small changes make a big difference so take it easy when raising it. To high will make the boat very loose and make it easier to have a wreck. The other thing to consider is the water condition. Glass smooth water will not be as fast as when the wind is blowing small waves.
          • Crash
            • Oct 2015
            • 313
            #290
            great reply.
            thanks
            yes, the water was glass.
            I just removed the drive shaft to find the stuffing tube has broken loose and slide forward over 1/8 inch. there is a hot spot on flex cable where it enters stuffing tube as well.
            this is my second flex drive already and I am seeing signs of where after one set of packs. something needs fixing here I think.
            Dan
            • arrover
              • May 2015
              • 322
              #291
              I ran a Octura X452 three blade tonight. 66.2mph on 6S and 48.8 on 4S. I was kind of expecting more from this prop. Maybe it's to much for the motor. I'm not sure.
              Leopard 4092 1730kv, Tunrigy 180a ESC
              Temps after three back and forth passes:
              Motor: 112
              ESC: 117
              Capacitor pack: 127
              Motor connectors: 160
              Batteries: 92,99
              • arrover
                • May 2015
                • 322
                #292
                Originally posted by Crash View Post
                great reply.
                thanks
                Dan
                So the epoxy isn't holding the stuffing tube tight? That's certainly not right. I had to SLIGHTLY bend my stuffing tube up because I think my flex was rubbing on the inside of the strut nose. You may have to adjust yours.
                • arrover
                  • May 2015
                  • 322
                  #293
                  I had a chance to shoot some video today.
                  • Rafael_Lopez
                    • Jan 2015
                    • 470
                    #294
                    Wow Arrower, Great job!! I'm willing to bet the hull has another 10-15 MPH before it starts to get upset. Happy to see you pushing this hull faster and faster each time I peak my head in here. I'm going to share your video on my FB page, if you don't mind.
                    Rafael Lopez
                    Product Developer-Pro Boat
                    • arrover
                      • May 2015
                      • 322
                      #295
                      Thanks! I don't mind you sharing the video. That's why I film them. 80-85 is something to shoot for! I'm enjoying the process of testing and tuning.
                      • arrover
                        • May 2015
                        • 322
                        #296
                        Ran a Prather 235 this morning to 62.0mph and 39.2 on 4S. I wasn't able to take temps because I didn't have my temp gun with me. Temps didn't seem to bad just by feel. Water was very calm. Leopard 4092 and Tunrigy 180a.
                        • zooma
                          Local club FE racer
                          • May 2014
                          • 653
                          #297
                          Hi arrover,
                          I presume that you are just running straight ahead for a few seconds, then coming back in to get the reading. Is the boat stable enough to do laps around an oval course?
                          Ron - The Villages, FL
                          • arrover
                            • May 2015
                            • 322
                            #298
                            Yes I run as you describe. You can see it in the video a couple posts up. My boat is pretty darn stable with most of these props. It got out of shape in the video because of the wind and my own wake. So if you are doing laps around a course with other boats, you might need to set the boat up so it's a little more settled than mine. It would probably be slower but handle wakes better. I almost always have calm water so that's how I have my boat set up. I have spoken to rcboone2000 and he has his boat set up looser than mine so it is fast but the handling suffers. The way mine is now, I can still sport run the boat and run laps just like it was stock. I'm not sure I could run 70mph laps for a full set of packs though. Things would probably overheat but I haven't tried it. Hopefully that answers your question.
                            • Tamelesstgr
                              • Jun 2014
                              • 1512
                              #299
                              Truly awesome!! Thanks for doing such a great job documenting and keeping us up to date! Do you have any type of datalogging capabilities?
                              NEVER SATISFIED RACING
                              Fine Design 32 V-Hull 4082+6s
                              • zooma
                                Local club FE racer
                                • May 2014
                                • 653
                                #300
                                understood
