DF pirate 35 build
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    #181
    Rick, do you see problems with water coming in having such a short tube?
    That's my concern here.
    I'll post pics tonight of my two layout considerations
    • rickwess
      • Apr 2013
      • 777
      #182
      No issues with water coming in.
        Make Total Destroy
        • Mar 2014
        • 1952
        #183
        Is the Teflon in any way partially responsible for that?
        I'm not planning to use one
          Very Nice!
          My $.02 is that a lot depends on the style of the motor mount or whether there is a set of stringers. With provision for mounting the ESC on top of the motor, it makes sense to have the motor in the rear and batteries in the middle and ahead of the motor. TFL or the new style Kintec mount precludes this arrangement. If one is going to mount the ESC ahead of the motor, then just like M-A-W said, with the batteries on the side, exact motor location is less crucial as there is much room for the batteries to move and achieve desired COG.
          I had a similar mount as Rick's and here is my MHZ Lizard Xtreme:DSCN2988_2448.jpgDSCN2985_2445.jpg
            Originally posted by Luck as a Constant View Post
            Ide love em man.
            How do you mount stuff without them tho?
            Building mostly cats, the tray fits from tunnel to outer wall and contacts all the way down (of course after narrowing them on the belt sander) and are epoxied all the way down. On cats that have a much wider sponson (cheetah) I've used the tabs in conjunction with glueing to the tunnel. I'll be making my own trays soon on my CNC router so I wouldn't have to worry with tabs anymore. Pm me your address and how many tabs you need and I'll send them to you.
              Make Total Destroy
              • Mar 2014
              • 1952
              #186
              Ok hard to see but here the two layouts
                My personal preference is the first picture.
                BTW, your inlay looks fabulous!
                  Make Total Destroy
                  • Mar 2014
                  • 1952
                  #188
                  Motor in the rear.
                  Yeah it would make things more accessible
                    Make Total Destroy
                    • Mar 2014
                    • 1952
                    #189
                    Thanks brosef!
                    • rearwheelin
                      • 2101
                      #190
                      Front mount makes the nose plow threw the chop better . Going to re do Rumdog's Rico front mount.
                      --Albert Einstein
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        #191
                        Travis, cool builds you are doing lately by the way! just noticed you mentioned epoxying lipo mounts in the hull, have you ever thought of using something like wurth windscreen adhesive? it holds miles better and wont crack if you have a hard crash. Almost impossible to come loose but can easy be cut out with a box cutter :) Would be interested in what kind of CNC router you are building/running, (a big passion of mine, or use to be anyway lol)
                        • rearwheelin
                          • 2101
                          #192
                          Awesome method ! Thanks !
                          --Albert Einstein
                            I'm gonna send you a pm so we don't clutter his thread.
                            Luck....I found you a couple. This should do. I'll get em in the mail for you maybe tomorrow.
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              #194
                              I was thinking about trying urethane windshield adhesive.
                              It's black and flexible. I wonder if it would work ok....
                                Make Total Destroy
                                • Mar 2014
                                • 1952
                                #195
                                Thank you sir!
