DF pirate 35 build
  • rearwheelin
    • 1941
    #166
    Need a pic luck
    --Albert Einstein
    • rearwheelin
      • 1941
      #167
      I used Quick Steel on my T29 and my current Team Believer build . It's the way to go for me !! Cures fast and sticks like epoxy. image.jpg
      --Albert Einstein
      • Luck as a Constant
        Make Total Destroy
        • Mar 2014
        • 1952
        #168
        Originally posted by rearwheelin View Post
        Need a pic luck
        ill get one tomorrow.
        its possible the Kintec stuff shows up tomorrow. tracking says it left the shrewsbury sort facility today at 4. 30 min drive from me....
        ose orders are usually fast as well, considering its 30 minutes away the other direction.
        i have to stop into the store someday..
        • Savage Skidoo
          • May 2011
          • 312
          #169
          I used Jb weld , then i made a small wooden wedge for the hull to the tube reinforcement . Then i wrapped it in CFK and west .
          www.facebook.com/Boaters and Crawlers Durham
          Durham Off Road Rc Club - www.dorc.ca founding member
          • rearwheelin
            • 1941
            #170
            Originally posted by Savage Skidoo View Post
            [ATTACH=CONFIG]128879[/ATTACH][ATTACH=CONFIG]128880[/ATTACH]
            Quick Steel would have been perfect for that !
            --Albert Einstein
              Make Total Destroy
              • Mar 2014
              • 1952
              #171
              More stuff today
              I forgot to get the tail ring and the cf mounting plates came with No tabs?
              How am I gonna mount them,,, "scratches head"
              I put in another order with kintec for some more stuff including that pesky ring.
              I went with 2075 servo. It's pretty quick and powerful. I've always liked them.
              Here's my stuffing tube
                Originally posted by Luck as a Constant View Post
                More stuff today
                If you need those little tabs for the battery trays I have plenty. I hardly use them.
                  Make Total Destroy
                  • Mar 2014
                  • 1952
                  #173
                  Ide love em man.
                  How do you mount stuff without them tho?
                  • rearwheelin
                    • 1941
                    #174
                    Originally posted by Luck as a Constant;
                    Here's my stuffing tube [IMG
                    http://tapatalk.imageshack.com/v2/15/03/09/73c953bc38c65ece0e9c1c295af2c06c.jpg[/IMG]
                    Looks like a forward in the hull mount from the length of brass. You won't find a stronger way than with quick steel to secure that stuffing tube . I used it in conjunction with JB. I experimented with my T29 build with the putty and it's just a easy cheap way but stupid strong. If you are into looks you can do a better job than me and sand it smooth. I just try to form it smooth and don't care about the detail so much, that's why I just brush JB over it and around the edges where it's stuck to the hull. Super strong and distributes forces better because it's stuck to more square inches of hull.
                    --Albert Einstein
                      Make Total Destroy
                      • Mar 2014
                      • 1952
                      #175
                      Well I could go up front or in back.
                      If I mount a motor in the rear, and have a short stuffing tube, is it more prone to leaking?
                        Make Total Destroy
                        • Mar 2014
                        • 1952
                        #176
                        From my experience with df mono hulls, is they seem to not like much weight in the back. Not sure on this hull tho
                          • 5554
                          #177
                          I find the opposite with the weight, the cog's i run in my monos are like 28-30%. The motor placement is not that big and issue really but with forward mounted you dont have such an angle on your tube. Weight can be adjusted easily with the batts, especially with the 2p you will run. You are gonna have the batts on the sides right?
                          • Kaotic
                            • Jul 2014
                            • 447
                            #178
                            Same here. On my DF35 my motor is in the middle and balances out at 30%. Im building it so I can move my 2p setup forward or backwards to adjust between COG between 26-38%. (More room to move weight forward)
                            Michigan Fast Electric SAW Club
                            Revolt - 76.9mph...Building a DF35- Project Mono
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              #179
                              Yes. That's the plan
                              • rickwess
                                • Apr 2013
                                • 777
                                #180
                                The bend is not not bad at all and lots of room to move batteries around. The batteries all the way to the rear is 27%.
