DF pirate 35 build
  • Kaotic
    • Jul 2014
    • 447
    #211
    Aluminum brite
    Purple power
    Greased lightening
    All remove anodizing. Aluminum brite is the strongest. Be careful, it will bubble up and will ruin anything it gets on. I got it on ceramic tile on my bar. Wife wasn't happy.
    I use good old Lye. Works in under 10 minutes.
    Michigan Fast Electric SAW Club
    Revolt - 76.9mph...Building a DF35- Project Mono
    • Luck as a Constant
      Make Total Destroy
      • Mar 2014
      • 1952
      #212
      Today I recieved my 24v power supply from Joel (rockstar) and some black cooling hose tossed in. Thanks Joel always a pleasure...
      I took s ride to my lhs for a few things.
      I did grab a traxxas waterproof reciever box, and particularly some flat cf rod to glue down before the motor mount. The small amount in height will make a huge difference in getting a wrench in there if ever needed.
      Also I grabbed some larger brass to try for the servo to rudder rod. Usually I use 1/4 brass but I wanted to try larger. Turns out the boot can stretch to fit over 5/16
        Make Total Destroy
        • Mar 2014
        • 1952
        #213
        Got some work done today.
        Mounted the servo, stuffing tube, brass tube and boot for steering rod, and layed two strips of cf flat rod for the motor to mount on top of
          Make Total Destroy
          • Mar 2014
          • 1952
          #214
          Oh and I got the jacket on the motor
          • rearwheelin
            • 1941
            #215
            Too bad the mount wasn't wider . The water entry to the motor jacket should be on the side close to the motor plate with the water exiting at the top end bell side ... So the air pocket escapes .
            --Albert Einstein
              Make Total Destroy
              • Mar 2014
              • 1952
              #216
              Gotcha.
              More like this? Exit at top
                Looking good! Started on my mono today. I'm excited
                  Make Total Destroy
                  • Mar 2014
                  • 1952
                  #218
                  Yesway
                  • Make-a-Wake
                    FE Rules!
                    • 5554
                    #219
                    This is coming along nicely!
                      Make Total Destroy
                      • Mar 2014
                      • 1952
                      #220
                      Thanks.
                      The easiest way to make a nice black stuffing tube is to just use shrink wrap.
                      Because I have a gap it was easy.
                      • Fella1340
                        • May 2013
                        • 1025
                        #221
                        The build is looking awesome, really nice work. What did you end up using as an adhesive to glue everything down? Windsheild adhesive is incredible stuff, I,ve installed a few windshields and used it on big boats. It held a fullsize 12volt marine battery mount in place in a speed boat that ran some big water, still doing the job 10 plus years later. Sikaflex is another great one, used a lot in big boats. I really like how neat you got everything installed, any good tricks for glueing everything in so nice?
                        Last edited by Fella1340; 03-15-2015, 10:50 AM. Reason: needed to make it make sense!
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          #222
                          DF pirate 35 build
                          Thanks.
                          I haven't glued in the trays or motor yet.
                          The windshield guy that comes to my shop offered me a tube of the urethane and some primer if I want to try. Stuff is super messy tho.
                          The other option is black aquarium sealant. I still can't wrap my head around that tho.
                          When I glued in the servo and flat rod for motor mount, first I sanded some cf rod onto a piece of paper to make dust to color my epoxy.
                          Then I took a piece of fabric is cut the ends of if with shears repeatedly to get sort of milled cf.
                          then I just Mix it into my epoxy, tape off areas I don't want it, and try to use only as much as needed.
                          Spreading glue everywhere def doesn't help hold things in place.
                          • rearwheelin
                            • 1941
                            #223
                            Originally posted by Luck as a Constant View Post
                            Gotcha.
                            Exactly !
                            --Albert Einstein
                            • Make-a-Wake
                              FE Rules!
                              • 5554
                              #224
                              Hey Luck, make sure you tape everything off really good to not get the goop all over that nice build. I use a small trash bag a lot for the hull and just cut the small hatch opening in it and tape it secure with painters tape.
                                Make Total Destroy
                                • Mar 2014
                                • 1952
                                #225
                                Back at it tonight.
                                For the motor and esc mount I picked up some west 406.
                                To color it I sanded a scrap piece of cf Rod.
