DF pirate 35 build
  • Make-a-Wake
    FE Rules!
    • 6057
    #256
    Never heard of those batts............ever run them before?
    I see you went with the affordable workhorse Traxxas 2075 servo................great bang for the buck!
    • Luck as a Constant
      Make Total Destroy
      • Mar 2014
      • 1952
      #257
      i havent. Keith Bradley had mentioned them, so i figured why not give em a try.
      Yes the traxxas 2075 are awesome... digital and waterproof. tons or torque too
        Make Total Destroy
        • Mar 2014
        • 1952
        #258
        Tonight I got some Velcro down on the trays and mounted the batteries. Also ran the cooling lines for inside the hull.
        These little details take time
        • Fella1340
          • May 2013
          • 1025
          #259
          You've done an excellent job there, top shelf stuff! I'm sure you couldnt be more happy with it yourself. Look forward to seeing it set and sitting in the water with some nice video!
            Make Total Destroy
            • Mar 2014
            • 1952
            #260
            Absolutely man.
            I'm down to the nitty gritty stuff here.
            It's pretty heavy with the batteries in there.
            Should be s good runner thru the chop here in New England.
              Make Total Destroy
              • Mar 2014
              • 1952
              #261
              DF pirate 35 build
              Today I made a brace for the stuffing tube
              Then glued in
              Also buttoned up the wiring to the rx. Put some Vaseline on the channel the rubber sits in for the radio box
              So everything is in.
              Only things left are, mount water exits, fashion a way to hold down esc, and hatch mounting.
              I did a bathtub test, and it's dry inside. No leaks = Win!
              • Roy Van De Sande
                • Nov 2013
                • 143
                #262
                Clean job! When will she see the water :)?
                  Make Total Destroy
                  • Mar 2014
                  • 1952
                  #263
                  Thanks bro.
                  Well, as soon as the ponds unfreeze around here.
                  Looking like within the next week or two depending on the weather.
                  Cmon sun!
                    Make Total Destroy
                    • Mar 2014
                    • 1952
                    #264
                    Got the esc mounted in there tight today.
                    This thing is ready after I get the hatch mounted.
                      Luck, that looks great, I love your approach, it's got character!
                      I am still kicking myself for not buying your Miss Elam conversion.
                        Make Total Destroy
                        • Mar 2014
                        • 1952
                        #266
                        Thanks bro!
                        Yesway
                        • Make-a-Wake
                          FE Rules!
                          • 6057
                          #267
                          Just great work here............. perfect timing for spring too!!!
                            Originally posted by Luck as a Constant View Post
                            Absolutely man.
                            you see how much mine weighs with (2) 3s packs in it? (9.796lbs)
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              #269
                              I did see that.
                              Christ mine has to be around 11-12 I swear. It's a rock.
                              It floats tho! Lol
                                Make Total Destroy
                                • Mar 2014
                                • 1952
                                #270
                                Aw dude, I can hardly wait.
                                Part of me has the butterfly's too tho
