DF pirate 35 build
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    #31
    The Neu 1521 is plenty enough. A 1527 is complete overkill in that hull. The 1521 is a bit Larger than a 4082 Leopard and more efficient, I would put it right there with a 4092 Leo powerwise. The 1577kv would be great for 6s2p and I would get a 200a+ ESC.
    Thanks for the reply.
    Do you have experience with the sf esc?
    • Make-a-Wake
      FE Rules!
      • 6057
      #32
      Here's the 200a Swordy that powers my 39" mono, Castle 1717 6s2p....................bulletproof.............so far.
        Make Total Destroy
        • Mar 2014
        • 1952
        #33
        thank you good sir!
          Make Total Destroy
          • Mar 2014
          • 1952
          #34
          Boat and cf showed up today.
          And it begins
            And it begins
            I will be watching this as well.
              Make Total Destroy
              • Mar 2014
              • 1952
              #36
              Yesway
                Make Total Destroy
                • Mar 2014
                • 1952
                #37
                How do you guys feel about zpoxy?
                I have it here... But not sure if it's great...
                Lmk
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  #38
                  I one-upped ya!!
                  • Make-a-Wake
                    FE Rules!
                    • 6057
                    #39
                    Ok.........what motor????????? 1521, 1717, 4082, 4092 etc...............???
                      Make Total Destroy
                      • Mar 2014
                      • 1952
                      #40
                      Lol
                      Still not sure but it will either be a 1521 or a 1717.
                      I have plenty to do before I need to decide, and there's at least 5 feet of snow in my front yard
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        #41
                        In my opinion the 1717 will have a little more gusto than the 1521. Its got Neu's "blessing" and most likely Neu's quality control. Plus its a bit bigger 46 x 85mm to the 1521 at 40 x 84
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          #42
                          Yeah I see what you mean.
                          As far as power goes tho, which has more?
                          • flraptor07
                            • Aug 2013
                            • 2451
                            #43
                            On the Zpoxy thing, that's about all I use 5min. and 30min depending on what I'm doing. I've never had anything come apart that wasn't my fault and that was only one thing. If I'm doing motor mounts or something like that I mix either milled fiberglass or milled Carbon Fiber with it to make it thicker, stronger and to color it. IMO Good Stuff !!! Their Finishing Resin is good too!
                              Lmk
                              I have used the 30 min. Z-Poxy extensively, good stuff. The only thing is that it is pretty sensitive with the mixing ratio, and I am always afraid to have incorrect 1:1 ratio that I pour enough to the mixing cup for a precise reading. In the end, I have wasted quite a lot. Some people use a tiny amount on a piece of card board to mix, haven't figured out that technique out yet... Also when they say 30 min. pot life, I often wish it is still longer.
                                Make Total Destroy
                                • Mar 2014
                                • 1952
                                #45
                                So I gotta work fast I guess lol
