Aeromarine Team Believer with updated hatch build. Special
Added a Garmin 101 powered by the reciever and top dollar pool noddles from sport chalet ( didn't have orange )image.jpg"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
Ok this my grand foo-nally lead up to my run tomorrow if everything goes as planned video enjoy
Video: http://youtu.be/C9RSijVC-1w"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
Thanks man ! Blue tape off tomorrow !Originally posted by tlandauer View PostRandy, this is fabulous, good luck tomorrow!
Now if you don't mind my asking: when are you going to take the blue masking tape off
Man, wish I have a trailer like that! The bike is real nice!!
--Albert Einstein
Fully RTR with 6s 2p , 16,000mah is 18.14 lbs ! Just waiting on a friend to show up then we are rolling to the lake !
--Albert Einstein
--Albert Einstein
The caps on the V3 burned up or almost burned up . Speed control still works but the caps on the speed control itself need changing and I think they aren't replaceable . I didn't run for long before this happened . The boat cut out and so it sat for a couple seconds and it seemed to work again. I cruised it in and it seemed fine pumping water for a while . Then noticed some smoke .
the thermal switch got so hot it stuck closed lol both batteries discharged at the same rate so I think I can rule out the battery harness being restrictive . I noticed early on when running that the prop needed to come up some more and I wish I just brought it in then but I had no idea the caps would get so hot soo fast lol the good news is it could have been worse if I had no thermal system . image.jpg
--Albert Einstein
Last edited by rearwheelin; 04-03-2015, 07:28 PM."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
