Aeromarine Team Believer with updated hatch build. Special
  • rearwheelin
    • 2101
    #151
    8 gauge battery harness. 6.5mm CC on batts and 8mm CC to the esc. 6.5mm CC on the motor. 3p setup.
    --Albert Einstein
    • rearwheelin
      • 2101
      #152
      This is how I solder bullets .
      --Albert Einstein
      • Luck as a Constant
        Make Total Destroy
        • Mar 2014
        • 1952
        #153
        Now that's how you do it!
        I may hit you up for some when I'm ready
        • rearwheelin
          • 2101
          #154
          Any time Luck as long as there is heavy sacks of coin involved
          Just need to insulate a few loose end and there ready
          --Albert Einstein
          • rearwheelin
            • 2101
            #155
            --Albert Einstein
            • Fella1340
              • May 2013
              • 1025
              #156
              Looking great! You really dove right back into this build and tore it up!
              What are you doing for battery trays? I noticed you had one 8000mah set on the tunnel, is that where you plan on leaving it? I ask because you'd be better served with them in the sponson, nice long ones you can use to set the cog wherever you please.
              • rearwheelin
                • 2101
                #157
                You posted just at the right time :)
                Long Lexan trays ! They are drilled for zip ties and will have 2" Velcro . The center will have the same securement for 3p
                --Albert Einstein
                • rearwheelin
                  • 2101
                  #158
                  --Albert Einstein
                  • rearwheelin
                    • 2101
                    #159
                    --Albert Einstein
                    • rearwheelin
                      • 2101
                      #160
                      --Albert Einstein
                      • rearwheelin
                        • 2101
                        #161
                        --Albert Einstein
                        • rearwheelin
                          • 2101
                          #162
                          Re-did the center tray . This about sums it up for the weekend
                          --Albert Einstein
                          • rearwheelin
                            • 2101
                            #163
                            I'm thinking of building a cap bank that plugs into the battery harness. Good idea ?
                            --Albert Einstein
                            • rearwheelin
                              • 2101
                              #164
                              1st night of finishing the JB welding the battery trays in. I will get the other side tomorrow . $17.99 sheet of lexan goes a long way on this build ! The lexan actually is really stout once epoxied in.
                              --Albert Einstein
                              • rearwheelin
                                • 2101
                                #165
                                There different but will be very strong. I think they go with the boats theme well to .. Ha Ha !
                                --Albert Einstein
