Aeromarine Team Believer with updated hatch build. Special
  • NativePaul
    Greased Weasel
    • 2764
    #346
    Damn those are some long battery wires, no wonder you have gone cap crazy.
    • rearwheelin
      • 1941
      #347
      Yeah no doubt . Bunch of 8 gauge there lol flows great though , never hit LV cut off and the 6s 2p discharged evenly . I just figured the cheesy caps of the v3 couldn't take the poke of a 59mm 1800 kv can lol
      --Albert Einstein
      • rearwheelin
        • 1941
        #348
        I'm really liking this switch location.
        --Albert Einstein
        • rearwheelin
          • 1941
          #349
          --Albert Einstein
            Is it absolutely necessary for the wires to be that long? In all honesty it's more important for your wires to be as short as possible than to worry about aesthetics. Not trying to undermine you one bit but I really think it's very important to make them a good bit shorter. Longer wores like that are causing a bit more unneeded stress to your power system. I'm unsure whether the caps will help as much as needed
            • rearwheelin
              • 1941
              #351
              No not totally necessary they need to be this long . I did shorten up the motor leads about a inch . You could be right but I like testing my handy work too lol
              --Albert Einstein
              • rearwheelin
                • 1941
                #352
                Next thing I want to do is even up the drive dog with the rudder. This will bring it closer to an acceptable setup and should cut down on amp spikes a little bit when the nose goes high , along with the smaller prop I'm going to put on it .
                --Albert Einstein
                • rearwheelin
                  • 1941
                  #353
                  So went a little more positive on the strut from my original setting on the strut memory clamp(TM) image.jpg
                  --Albert Einstein
                  • rearwheelin
                    • 1941
                    #354
                    --Albert Einstein
                    • rearwheelin
                      • 1941
                      #355
                      This is the difference from the last one.
                      --Albert Einstein
                      • rearwheelin
                        • 1941
                        #356
                        --Albert Einstein
                          • 5660
                          #357
                          Looks good, can't wait, good luck!
                          STRUT MEMORY CLAMP (TM)-----me likes
                          • rearwheelin
                            • 1941
                            #358
                            And we got some 8 gauge Rearwheelin Batt Fire Wire (TM)
                            --Albert Einstein
                            • rearwheelin
                              • 1941
                              #359
                              --Albert Einstein
                              • rearwheelin
                                • 1941
                                #360
                                Pretty cool way to tighten and loosen prop nuts . Folded Lexan and a vise .
                                --Albert Einstein
