Aeromarine Team Believer with updated hatch build. Special
  • rearwheelin
    • 2101
    #286
    --Albert Einstein
    • rearwheelin
      • 2101
      #287
      --Albert Einstein
      • rearwheelin
        • 2101
        #288
        As boat sits RTR minus 16,000mah 6s 2p , minus floatation , minus hatch seal , minus a couple zip ties : weight is recorded at 12.86 lbs. image.jpg
        --Albert Einstein
          Randy, how does the orange stripe change its color? Did I miss anything?
          • rearwheelin
            • 2101
            #290
            It is orange reflective motorcycle wheel striping that I got at cyclegear :) all lights and decals were bought at autozone , cyclegear and my local Ktm dealer. Some of the decals I had already that came with parts purchases or just made them with scrap sheet .
            --Albert Einstein
              I see, the change of color is the result of the reflection from your flash may be?
              Very nice choices of materials! To me it just shows that with good selection of decal, one can have a cool looking boat, I am saying this because I can't paint and am too cheap to spend $500 or $600 on a panit job. Plus, I use tape, so no peeled paint if gel coat is left alone.
              • rearwheelin
                • 2101
                #292
                Boat lighting walk around video
                Walk around vid : http://youtu.be/OTPTFrSDObw
                --Albert Einstein
                • rearwheelin
                  • 2101
                  #293
                  Some features .
                  Shaved bottom of V3 down to the copper heat absorbing compound and JB welded the esc directly to an aluminum plate with a water cooling on the underside of plate. Thermal switch JB welded directly to the copper esc compound . Switch closes @ 120F and sends power to exterior yellow LED's and a inboard water pump.
                  Second thermal switch located on the capacitors on the battery leads. Heat sink for the esc caps.
                  Servo switch closes at full left turns and sends power to the water pump and warning lights for on demand cooling while not moving or to simply make sure the system is functioning .
                  --Albert Einstein
                  • rearwheelin
                    • 2101
                    #294
                    Strut adjustment memory clamp and frictionless servo boot.
                    Water pickup for pump.
                    Lexan this and that. CF this and that . Too many 8/32" drill taps to list. JB weld and QuickSteel epoxy putty , Honda Bond 4 . Custom oiler :)
                    --Albert Einstein
                    • rearwheelin
                      • 2101
                      #295
                      I don't paint very well so the decals suited me well and if something cracks or gets damaged it fixes much easier without paint all over it ! Painted boats are purdy but ad to much expense to a build and in some cases decrease the value. For me I want to run this thing with no worries that the paint will get damaged should the hull crack here or there. I can fix cracks in fiberglass fine but don't want to deal with paint ! Ben there done that ! lol
                      --Albert Einstein
                      • rearwheelin
                        • 2101
                        #296
                        Hatch seal is done . Did a light tape job and tested it. Worked great , no water got in ! Test vid lol : http://youtu.be/7ecQvMsKni0
                        --Albert Einstein
                          [ATTACH=CONFIG]130403[/ATTACH]
                          [ATTACH=CONFIG]130404[/ATTACH]
                          There has never been and will never be another "maiden teaser " quite like this one.
                          Looks good!!
                          How do you secure the hatch seal? Is there adhesive on the back? I am finally seeing the light on hatch locks but am foggy with this concept...
                          • rearwheelin
                            • 2101
                            #298
                            It's rubber foam weather seal self stick I got at the Depo new vid lol : http://youtu.be/SJ9suJiEVRc
                            --Albert Einstein
                              Thanks, demo is great!
                              • rearwheelin
                                • 2101
                                #300
                                Your welcome
                                So how much would you give me for it ???
                                --Albert Einstein
