Aeromarine Team Believer with updated hatch build. Special
--Albert Einstein
As boat sits RTR minus 16,000mah 6s 2p , minus floatation , minus hatch seal , minus a couple zip ties : weight is recorded at 12.86 lbs.
--Albert Einstein
It is orange reflective motorcycle wheel striping that I got at cyclegear :) all lights and decals were bought at autozone , cyclegear and my local Ktm dealer. Some of the decals I had already that came with parts purchases or just made them with scrap sheet .Originally posted by tlandauer View PostRandy, how does the orange stripe change its color?
Did I miss anything?
--Albert Einstein
I see, the change of color is the result of the reflection from your flash may be?
Very nice choices of materials! To me it just shows that with good selection of decal, one can have a cool looking boat, I am saying this because I can't paint and am too cheap to spend $500 or $600 on a panit job. Plus, I use tape, so no peeled paint if gel coat is left alone.
--Albert Einstein
Some features .
Shaved bottom of V3 down to the copper heat absorbing compound and JB welded the esc directly to an aluminum plate with a water cooling on the underside of plate. Thermal switch JB welded directly to the copper esc compound . Switch closes @ 120F and sends power to exterior yellow LED's and a inboard water pump.
Second thermal switch located on the capacitors on the battery leads. Heat sink for the esc caps.
Servo switch closes at full left turns and sends power to the water pump and warning lights for on demand cooling while not moving or to simply make sure the system is functioning .
image.jpg"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
--Albert Einstein
I don't paint very well so the decals suited me well and if something cracks or gets damaged it fixes much easier without paint all over it ! Painted boats are purdy but ad to much expense to a build and in some cases decrease the value. For me I want to run this thing with no worries that the paint will get damaged should the hull crack here or there. I can fix cracks in fiberglass fine but don't want to deal with paint ! Ben there done that ! lolOriginally posted by tlandauer View PostI see, the change of color is the result of the reflection from your flash may be?
--Albert Einstein
Hatch seal is done . Did a light tape job and tested it. Worked great , no water got in ! Test vid lol : http://youtu.be/7ecQvMsKni0
--Albert Einstein
There has never been and will never be another "maiden teaser " quite like this one.Originally posted by rearwheelin View PostHatch seal is done . Did a light tape job and tested it. Worked great , no water got in ! Test vid lol : http://youtu.be/7ecQvMsKni0
[ATTACH=CONFIG]130403[/ATTACH]
[ATTACH=CONFIG]130404[/ATTACH]
Looks good!!
How do you secure the hatch seal? Is there adhesive on the back? I am finally seeing the light on hatch locks but am foggy with this concept...Too many boats, not enough time...
It's rubber foam weather seal self stick I got at the Depo new vid lol : http://youtu.be/SJ9suJiEVRc"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
