First build... Cheap boat, lots of power
    Originally posted by LarrysDrifter View Post
    The black "boot" you have to seal the steering rod. You post faster than anyone Ive seen on here!
    That's why we've gone thru so many pages here Larry
    • masonis1
      If you cant control it 👍👍
      • 1177
      #707
      Just noticed,, passed up the 700 point
      When speed isnt the option, change your ways
      • masonis1
        • 1177
        #708
        Hah shaun, howd the canucks do last night?
          Originally posted by masonis1 View Post
          Im really anxious to get this boat running.. hah so what about the steering lock question or what?
          Yes mason,Make sure you have enough straight rod to pass thru the transom.You don't want to have a bend ramming into the transom.
            hah shaun, howd the canucks do last night?
            grrrrrr
            • masonis1
              • 1177
              #711
              So should i start about 10mm from when the steering is at full lock?
                That should work.
                • masonis1
                  • 1177
                  #713
                  Ok.. also, it seems like when i bend, im going to loose where i had the rod lock. It will be shorter. So should i start the bend at the transom or at the rudder?
                  • masonis1
                    • 1177
                    #714
                    grrrrrr
                    Not good? Well my home team, the blues arent doing too well
                      We were battling with them for the President trophy.We won.Hehe
                      • masonis1
                        • 1177
                        #716
                        Ya dont braggg.. hah so back to the boat...
                        • LarrysDrifter
                          Big Booty Daddy
                          • May 2010
                          • 3416
                          #717
                          Put the bend right at the center between the transom and rudder arm, still leaving enough straight rod to pass through the transom.
                          • masonis1
                            • 1177
                            #718
                            Like can you do that picture editting like what u did to my servo and show what i should have the bend look like?
                            • masonis1
                              • 1177
                              #719
                              Im confused but my grandpa is a good mechanic, im sure he will know. Hah mechanic for 58 years...
                                I would mark the rod with a Sharpie where you want the bend to end before the transom.Then take the rod out of the boat and place in the vice and put a 30 degree bend rearward.Then about 3/4 inch put the opposing bend in it so the rod goes back to straight.
