First build... Cheap boat, lots of power
  • h2o 1
    • Sep 2011
    • 854
    #661
    If you have to bend it,start the bend from inside the boat,it looks like there is a serious bow there.take the steering rod off the servo,the rod will become unbound. Then bend the rod to the right angle to line up with the servo arm.Its best to use a vice for bending these,since u dont have a pipe bender
    • masonis1
      If you cant control it 👍👍
      • 1177
      #662
      But it will be strait out the hole from the servo horn if its not connected to the rudder, if i bend outside to make it over to the hole it would be straight but i dont know.
      When speed isnt the option, change your ways
      • h2o 1
        • Sep 2011
        • 854
        #663
        reread my last post u understand?
        • masonis1
          • 1177
          #664
          Yes but then it would be sideways going to the rudder... Hah. If i bend from rudder, it would go to the servo straight.
          • masonis1
            • 1177
            #665
            I think i understand but i dont know if i CAN bend outside the hull or is this a no no
            • h2o 1
              • Sep 2011
              • 854
              #666
              Ok, then thats what ur gonna have to do!If u had waited,i would have recommended putting the rudder arm linkage on the bottom.This would have gave you a straighter shot.
              • masonis1
                • 1177
                #667
                What? Hah i can still adjust i think.
                • masonis1
                  • 1177
                  #668
                  Ill take my boat down to my grandpas tomorrow, he has everything needed, epoxy, vice, etc. Hah so ya. I just know how to do this...
                    I believe I stated that last night,but it must've been late.
                    • masonis1
                      • 1177
                      #670
                      Oh im sorry. So shaun. What am i gunna need to do to fix this? Your bends are in the hull, how do i do this outside.
                        You'll need a pair of pliers too to make a nice clean bend.All is good Mason,I'm pretty sure none of our first boats were perfect.It's a learning curve.
                        • masonis1
                          • 1177
                          #672
                          Ok. I hope i didnt ruin the steering. Hah.
                          • h2o 1
                            • Sep 2011
                            • 854
                            #673
                            Nevermind.Angles bro! its all about the angle!! If a bend on the outside is easier for you,go with that. But look at the pic slash posted for you,if you need bends ,this is the right way!!
                              All that matters is that the rod slides straight as it goes thru the boot/hull.Did you notice what was wrong with the bends in the pics.
                              • masonis1
                                • 1177
                                #675
                                Ok. I just noticed one had some curved bends and the other has flat, straight and sharp bends.
