First build... Cheap boat, lots of power
  • Make-a-Wake
    FE Rules!
    • 6057
    #691
    Mason, you may have to lop off those screwhole towers in the hull
    REMEMBER!! Get the rod hooked up to the rudder and servo horn and let it flow to where it wants to sit(within reason) then epoxy it down there and set a heavy object on it or hold it down if you are using 5 minute epoxy.
      This is the best way to insure that there is no binding.
      • masonis1
        If you cant control it 👍👍
        • 1177
        #693
        Even if the rod is not straight? If i do that, it will come out and an angle. Not curved but at an angle..
        When speed isnt the option, change your ways
          Just hook it up to the rudder arm and into the hull then take a pic from above.
          • masonis1
            • 1177
            #695
            I will when i fully get up.. im gunna lay back down and ill be on soon.
            • masonis1
              • 1177
              #696
              Here you go. Its just connected to the rudder...
              • LarrysDrifter
                Big Booty Daddy
                • 3416
                #697
                Id put a smooth "s"" bend on the exterior of the hull near the rudder bracket. That way, you can mount the servo nice and square in the hull. S bends are alot better than a "z" bend. Ideally a straight rod is best, but cant always be done. Also, I notice your antennae mount is close to the hatch. That ll make taping the hatch properly a bit of a pain.
                • masonis1
                  • 1177
                  #698
                  So what bend should i use? I have a vice... I can do anything, i just dont know where to bend and how hard to bend.
                  • LarrysDrifter
                    Big Booty Daddy
                    • 3416
                    #699
                    An S bend as I said. Put it where the bellow is in the last pic you posted is. Obviously, you want the rod straight off the rudder arm, then the S bend, the the rod straight into the hull.
                    • masonis1
                      • 1177
                      #700
                      Ok i think i can do that. So make it straight to the hull, then bend to go straight in... How far back should i make the bend?
                      • LarrysDrifter
                        Big Booty Daddy
                        • 3416
                        #701
                        Starting at the transom, straight, then begin the bend at the rudder stand off. Bend a little at at time until you get a straight shot to the rudder arm. Start the bend about 10-15mm from the transom. Put the bellow inside the hull if you can.
                        • masonis1
                          • 1177
                          #702
                          Whats the bellow?
                          • masonis1
                            • 1177
                            #703
                            Now is that 10-15mm from the transom when the rudder is fully steered. Like lock to lock or at centered?
                            • LarrysDrifter
                              Big Booty Daddy
                              • 3416
                              #704
                              The black "boot" you have to seal the steering rod. You post faster than anyone Ive seen on here!
                              • masonis1
                                • 1177
                                #705
                                Im really anxious to get this boat running.. hah so what about the steering lock question or what?
