Originally posted by LarrysDrifter
View Post
First build... Cheap boat, lots of power
Put the bend right at the center between the transom and rudder arm, still leaving enough straight rod to pass through the transom.
I would mark the rod with a Sharpie where you want the bend to end before the transom.Then take the rod out of the boat and place in the vice and put a 30 degree bend rearward.Then about 3/4 inch put the opposing bend in it so the rod goes back to straight.Originally posted by masonis1 View PostOk.. also, it seems like when i bend, im going to loose where i had the rod lock. It will be shorter. So should i start the bend at the transom or at the rudder?
