First build... Cheap boat, lots of power
Hobby shops round here know NOTHING about boats. Also, none have sharpened and balanced props available.
Start out with a carbon/plastic prop for testing...............1.4 pitch in the 36-40mm diameter range. Anything larger will cause some unwanted torque steer/roll in a 22" boat.....................dont worry if you think the prop suggestion is "smallish", your boat is like a Ford Focus with a 600hp V8 powerwise.................it'll haull A$$............NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
and Larry.............love your Avatar, the tractor is cool and the whole idea of a tractor picture on a boat forum is pretty darn funny too!!!NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Buy a couple different sizes of props to try out, also check your temps frequently so you don't blow a motor or fry a battery. Different props put different loads on the motor so you don't want to have too much prop. Looking forward to this little boat launch and fly across a pond!Real men have shafts.
Did you grease the shaft???
Let us know what props they have locally.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
