First build... Cheap boat, lots of power
  • masonis1
    If you cant control it 👍👍
    • 1177
    #781
    Still nothing on the prop. So an octura x440?
    Sent from my PG06100 using Tapatalk 2
    When speed isnt the option, change your ways
    • izcain
      • Mar 2012
      • 274
      #782
      Sounds like it was be a good start. I am really curious how this hull is going to handle all this newfound power lol.
      CF Fightercat Daytona, 21 year old Hitec Sea Nymph, Genesis and many more to come im sure.
      • masonis1
        • 1177
        #783
        Hah ya. I mean it twists with the torque out of water.. hah so the octura or what?
        • Make-a-Wake
          FE Rules!
          • 6057
          #784
          Thats the largest i would go...............a 438 is probably better. You're gonna be able to pull "wheelie's" off the line ya know!!
          • masonis1
            • 1177
            #785
            Hahah ive seen an awesome video where a miss long lite jumps out of the water like a foot and lands then shoots off. Hah.
            • masonis1
              • 1177
              #786
              Damn props seem very expensive
              • masonis1
                • 1177
                #787
                http://www.youtube.com/watch? v=lhZlQtoya6s&feature=youtube_gdata_player
                I want this!!! Just in my boat...
                • izcain
                  • Mar 2012
                  • 274
                  #788
                  I would start off as small as I could find something like the 35mm and work up. That is going to have a ton of bite with a big wheel on.
                  • masonis1
                    • 1177
                    #789
                    That small prop will?
                    • izcain
                      • Mar 2012
                      • 274
                      #790
                      I think I would just buy some plastics and then drill the centers out to suit your larger prop shaft for now and try them out. Once you have a proper prop setup then I would invest in a nice copper or stainless one. But thats just my .02
                      • masonis1
                        • 1177
                        #791
                        I have some smaller ones but i think they will be weak with so little of the coupler left
                        • sailr
                          • 7128
                          #792
                          Originally posted by masonis1 View Post
                          For the transom??? Could i add a piece of plastic of aluminum to stiffen it up? Also, what were the things for the drive lines i needed. Everything i get here should be able to cover over onto a different hull correct?
                          Epoxy some 3/16" plywood on the inside of the transom and then seal it good with more epoxy.
                          Mini Cat Racing USA
                          www.minicatracingusa.com
                          • masonis1
                            • 1177
                            #793
                            Its already finished... I put a piece of plastic in..
                            • masonis1
                              • 1177
                              #794
                              I have like a couple octura 431 and up...
                              • masonis1
                                • 1177
                                #795
                                Too hard to drill out so im gunna try another prop i have.. unknown stats.
