First build... Cheap boat, lots of power
  • masonis1
    If you cant control it 👍👍
    • 1173
    #826
    Sent from my PG06100 using Tapatalk 2
    When speed isnt the option, change your ways
    • h2o 1
      • Sep 2011
      • 770
      #827
      Mason,measure the prop from tip to tip in mm.
      • masonis1
        • 1173
        #828
        Ok I ill do that..
        • masonis1
          • 1173
          #829
          About 38mm
            • 4297
            #830
            Ok,
            How about a pictures of the setup lay out in side the hull of the bout ?
            • masonis1
              • 1173
              #831
              What
              • izcain
                • Mar 2012
                • 274
                #832
                Mason that looked great for a first build Bud! Nice one!
                I am actually shocked at how stable that lil boat looked when running! Looks like it could handle a little more speed even.
                CF Fightercat Daytona, 21 year old Hitec Sea Nymph, Genesis and many more to come im sure.
                • LarrysDrifter
                  Big Booty Daddy
                  • 3278
                  #833
                  Wow! You really did it! Looks good. Most guys that come on here with an old hull that needs lots of work give up and leave the forum. Now, youre in....sucker!! Be prepared for an empty wallet and low funds in the bank account.
                  • masonis1
                    • 1173
                    #834
                    It did handle good and it didnt bounce too bad when it hit the wakes...
                    • masonis1
                      • 1173
                      #835
                      Nope.. hah i got other rcs for that...
                        • 7651
                        #836
                        Looks great Mason! Congratulations!!I agree the motor doesn't sound like it's getting everything it could.Did you post a pic of the final inside layout?
                        • masonis1
                          • 1173
                          #837
                          Yes i did. Well everything was loosely mounted just to test...
                          • Make-a-Wake
                            FE Rules!
                            • 5554
                            #838
                            What batt did you run???????????? Mah, "C" rating, and voltage please
                            The motor doesnt sound like its revving out............
                            • masonis1
                              • 1173
                              #839
                              1000mah 3s lipo 45-90c
                              • Make-a-Wake
                                FE Rules!
                                • 5554
                                #840
                                Thats your problem..............That batt only puts out 45a constant and that motor can pull 60-80 amps propped correctly. I think you need around a 3000-3500 40c 3s minimum.
                                With the better batt you can also step up on prop a bit i believe.
