First build... Cheap boat, lots of power
    It should work fine,not what I would do,but fine.But then I just blew $1200 on the last build.
    • masonis1
      If you cant control it 👍👍
      • 1177
      #77
      Ya i really dont have 1200 bucks... Hah. I have 1/8 rod so i could use that as i think you just said. I will try finding the props i have.
      When speed isnt the option, change your ways
        You will need a flex cable and prop shaft.Not 1/8 rod
        Like this http://www.offshoreelectrics.com/pro...?prod=ose-1085
        Actually not like...THIS is what you will need.
        • masonis1
          • 1177
          #79
          Ok. Could i use rod for mock up?
          • masonis1
            • 1177
            #80
            • masonis1
              • 1177
              #81
              Sounds good. What kind of tube should i get? I will check at my hobby store and see if they have flex tubing because they have a boat section.
                Sorry Mason,I'm doing a build/paint job for someone on the side. You should just get your parts and then go from there.You could for now prep the hull.Sand all the old crap off,wetsanding works best for this.Just get it looking smooth for primer.
                  You could ask the dude with the TFL strudder if it is for a 4mm shaft and if it has bushings.If it is as I figure then you'll need a 7/32 brass tube.Is that a bidding thing or just a buy thing on e-bay?
                  • masonis1
                    • 1177
                    #84
                    He said he would take 20 for buy it now
                      Am I correct with the 4mm and bushings?
                      • masonis1
                        • 1177
                        #86
                        I dont know yet. I will findout as soon as i can.. i will sand the boat down and clean it up.. also, how can i make a boat more bouyant?
                          Any foam pool noodle around?
                          • masonis1
                            • 1177
                            #88
                            No. I dont go to the pool much, i have the nose of the boat filled with foam tho. What else could i do... Also, can i run a water cooling from the rudder, to the motor, out the motor, to the esc, out the esc, and out the boat?
                              That is the idea.Only in this order,From rudder to ESC,out ESC to motor,out motor ,out boat.If the nose has foam in it that should do it.
                              • masonis1
                                • 1177
                                #90
                                Ok. After i finish putting the electronics in, should i fill the rest of the hull up?
