First build... Cheap boat, lots of power
  • masonis1
    If you cant control it 👍👍
    • 1173
    #121
    Should i get that asembaly?? Also what colors of paint should i get
    When speed isnt the option, change your ways
    • h2o 1
      • Sep 2011
      • 770
      #122
      That will work Mason.Its best to have the rudder on the right side of the transom on mono or v hulls,but u can always get the offset bracket later.You will also have alot of prop choices with the 3/16 shaft.
      • masonis1
        • 1173
        #123
        Ok sounds good. So for 35 bucks? Is that a good deal?
        • h2o 1
          • Sep 2011
          • 770
          #124
          Any colors you like!Since ur funds are limited,good ole Krylon enamel primer and paint is prob ur cheapest option
          • masonis1
            • 1173
            #125
            Ok.. so it cant we standard spray paint from home depot?
            • h2o 1
              • Sep 2011
              • 770
              #126
              Sounds fair to me Mason,if ur talking bout the one from izcain(Zac),he seems like a stand up guy and i dont think he would sell you junk!
              • h2o 1
                • Sep 2011
                • 770
                #127
                Yes,that paint will work too. Just make sure its enamel and you prime first.
                • Make-a-Wake
                  FE Rules!
                  • 5554
                  #128
                  Go buy a $2 pool noodle and cut it to fit in the front of the hull for flotation.
                  • masonis1
                    • 1173
                    #129
                    ok. good to hear about this guy. i will prime first. how many ciats of each do you think will be good? also, what should i use to seal up around the drive line and steering linkage and other...
                      • 7651
                      #130
                      Looks like you found the strut/rudder.Right on.Looks like you got a team working for you Mason.Hehe
                      • h2o 1
                        • Sep 2011
                        • 770
                        #131
                        One can of each should do it. Silicone works well,but do the sealing after you paint because the paint will not stick to the silicone unless its a paint grade silicone
                          • 7651
                          #132
                          I would spray the primer then sand with the 400 grit.That should get rid of the scratches from the previous sanding.
                          • masonis1
                            • 1173
                            #133
                            Ok im glad i have yall helping. I would be so lost without you two. Hah. I have had problems in the past with the paint getting what looks like is veins. Once i get the paint i will ask for more help.. im still really glad you are donating parts. Very kind.
                              • 7651
                              #134
                              http://www.offshoreelectrics.com/pro...prod=ose-80085
                              I have a guy wanting 35 bucks for a used system of this. Comes with everything i need for a drive system in my boat he says. He is sending pics to my email. Ill try posting them here for you to see if i should get it.
                              Anybody know if he can simply turn this strut around so the nose isn't buried in the hull.I don't think we want to get into a wet well here.
                              • masonis1
                                • 1173
                                #135
                                Into a what?
