I got the. I understand
First build... Cheap boat, lots of power
You have a bit of a downward angle on the prop there Mason.You have to put a gentle bend in the brass stuffing tube.Ideally,you will want the prop shaft/strut straight with the bottom of the hull.You can adjust it a bit either way later for tuning but straight to start.Do't worry about the bend as that is why we call them flex shafts.Originally posted by masonis1 View Post
Is this ok?
You guys can call me Shawn.
I drilled the pilot holes and everything. About to mount up the stand to the transom. Everything is coming to this.. after this, there will be pictures, then i need to know how to run my steering linkage and watercooling line... HahWhen speed isnt the option, change your ways
