First build... Cheap boat, lots of power
  • seehuusen
    • Apr 2012
    • 101
    #1336
    yeah, that does sound a bit much... What diameter prop was it you were running again? 40mm from memory?
    • masonis1
      If you cant control it 👍👍
      • 1177
      #1337
      I think it's like a 50x52
      When speed isnt the option, change your ways
        No way.A 50mm would flip that boat.
        • masonis1
          • 1177
          #1339
          It was what I was running on the MG
          • seehuusen
            • Apr 2012
            • 101
            #1340
            50mm sounds a bit crazy sized... LOL
            If you find out, please post it up :)
              Shouldn't be running it there either,you surely must mean a 40/52 3blade as I can't find a 50.
              • masonis1
                • 1177
                #1342
                It is something 50. I forget
                • seehuusen
                  • Apr 2012
                  • 101
                  #1343
                  far out!! I need to get a bigger prop, flog this 37mm mini prop off then!! :D
                  I was thinking of moving up to a 42mm prop anyway... Someone else told me to get another 37mm prop in a 3 blade configuration... any thoughts?
                  • masonis1
                    • 1177
                    #1344
                    The prop is a 42x55
                      That sounds better.Boats not torqueing over too much with that?Those are small hulls,fairly wide though.
                      • masonis1
                        • 1177
                        #1346
                        Yep. I did notice, the boat is handling better with more weight in the hull. Less torque twist and tracks straight
                          You can weight the one side to compensate somewhat.I used to mount the motor over slightly to one side to make up for it too.Mmmm,maybe I should do that with the Bling rocket.Should have new ESC's for the cat by the weekend.
                          • masonis1
                            • 1177
                            #1348
                            Nice. It does sit a little to the left and it would torque to the right so it's good.
                            • seehuusen
                              • Apr 2012
                              • 101
                              #1349
                              cool, yeah 42mm sounds closer to the mark :)
                              the prop you have would be 42mm @ 1.3pitch (e.g. 55mm travelled forward per revolution of prop)
                              my props sit in that 52mm to 58mm pitch as well... I gotta drill out this 35mm 1.7p prop I got, as that would be sitting at around the 58mm mark... Not sure if the pitch is too steep, time will tell I guess :)
                              Thanks for confirming the size of the prop Mason
                              • masonis1
                                • 1177
                                #1350
                                My prop also had some added pitch and was detongued
