DF Sniper 45
  • RCKong
    • Sep 2009
    • 1556
    #76
    Well I looked and I had a prather 55mm prop on it. I found a 60mm prop for a 1/4 shaft, and made some tubing shims to fit the 3/16 drive. It should be an improvement. I Also found 1 -2* of down angle I can take out of the stinger so I can lift the nose some. Looks like I'll have to order some props so I can get er dialed in
    • Punisher 67
      Ignore list member #67
      • 1481
      #77
      I have my Sniper at about 31% CG if that helps any and 10 cells on a 2028 is not going to harm it . the extra cell will give you an additional 6+miles per hour easy
      • RCKong
        • Sep 2009
        • 1556
        #78
        Cool. Thanks
        • RCKong
          • Sep 2009
          • 1556
          #79
          Well I managed to get a 63mph run out of the boat today but it was ugly. Every time I tried to give it alot of throttle, it would hook violently to starboard and torque steered so bad it was impossible to run in a straight line ???
          I'm puzzled by this, and I'm wondering if it could be this hydro prop I put on it...blowing water so hard on the rudder that it made it useless as far as steering the boat ???
          Ordered two new props for it X460, X462.
          • Rumdog
            • 6453
            #80
            What sero and linkage?
            • Make-a-Wake
              FE Rules!
              • 5554
              #81
              What exact prop was it that was so bad for it?
              • RCKong
                • Sep 2009
                • 1556
                #82
                Hitec 1/4 scale MG
                It was a big grimm 65mm prop I milled down to 60mm...
                http://www.offshoreelectrics.com/pro...od=dh-aqub9785
                works good on my hydro
                MAN that motor has alot of power.
                • RCKong
                  • Sep 2009
                  • 1556
                  #83
                  Rumdog I think yur right bud, the servo didn't seem to hold very well when I pushed on the rudder, it looks like the force of the water coming off the prop was moving the rudder - the more I put power to it the more it moved.
                  Thanks for the tip.
                  RCK
                  • RCKong
                    • Sep 2009
                    • 1556
                    #84
                    I've been busy with work but managed a few set up runs with this boat in the past few weeks, and it has improved alot. I added a 300oz 1/4 servo (holds now) and made a new rudder bracket to get the prop just past the back of the rudder and *WOW* is all I can say... I don't have video yet, but she was mid sixties wet (Still more in it) and driving like a big Cadillac SWWEEEEEETTT...
                    I want to thank every body for their input and support.
                    RCK
                    • Chrisg81983
                      • Jul 2011
                      • 1556
                      #85
                      Very cool glad to hear it ran well these df hulls run great even my df-41 rides awesome what props we're you running
                      Thanks
                      Chris
                      • Make-a-Wake
                        FE Rules!
                        • 5554
                        #86
                        Hey Kong..........what prop did you run this time??? Those 2028's are monsters arent they? I logged info when i had a CC200a HV in my mono and it was running right at 190-200a constant with 240a spikes. Thats 8000 watts.........over 10hp!!!!!
                        • RCKong
                          • Sep 2009
                          • 1556
                          #87
                          I have a X462 on it now, and all temps where around the 110* range. I hope to get some video of it running soon.
                          • bill34207
                            • Dec 2009
                            • 2553
                            #88
                            Don't forget to get a good still water shot so I can tie the build into the website projects page.
                            My YouTube Vids
                            • Make-a-Wake
                              FE Rules!
                              • 5554
                              #89
                              Kong was the run with 9s or 10s? I found that the best top speed was an x460 on 10s with my 47" mono.
                              • RCKong
                                • Sep 2009
                                • 1556
                                #90
                                I'm running 9s...might have to order some more 5s packs for 10s. I'll try and get a few pics Bill, and I'll more than likely bring it with me to the next meet. I'm going to start a new fantasm build, and Ray has a bunch of pics up on his cheetah build too.
