Thanks Doug, You've been a busy man lately. Did you get to have some fun at the Nats?
JAE Builds
Oh yeah, I had a blast.Originally posted by Nautiboyz View PostThanks Doug, You've been a busy man lately. Did you get to have some fun at the Nats?
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
Hey Fellas...so, should I be worried about using the original UL-1 ESC w/no added cap board? I have seen that the new one has a much bigger cap now...Originally posted by D.Smock View PostHi Mike.
The newer controls have a larger capacitor and they seem to be fine.
We did add caps to the older controls.
Doug
-Kent
i use the old style with no problemsee my fleet
: http://forums.offshoreelectrics.com/...hp?albumid=294
Sounds good...thanks Chuck! Are you getting much heat buildup on the older ESC?Originally posted by Chuck E Cheese View Posti use the old style with no problem
-Kent
no, everything is cool and i have run that thing about 30 times with no issues. the temps are all below 110 using 30c packs ranging from 3600 to 5000mah on a 1450 cut to about 48, pitched and cupped.see my fleet
Thanks Chuck! That def. makes me feel better about using it at the races...
-Kent
I sanded everything off except for the rear overhangs on the sponsons and the tub (left the rear overhang on the ski as well)Originally posted by 6S HYDRO View Posthow do you guys feel about sanding the sponson overhangs- it says in the manual theyre only for getting on plane and if you use a high power motor then sand them off
Hope that helps...
-Kent
i removed about 1/2 on the rear of the FE and left the nitro 12 and 21 full. i cant tell a difference but there is no issue with coming on a plane. i only did it on the fe to match the cut out for the turn fin.
see my fleet
The sides of our sponsons are sanded flush. These boats have no problem getting up with UL-1 power.MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
Three at a time
Here is the beginning of three builds I started yesterday for some friends that race gas boats. One is going to Michigan, one to Ohio, (D-2) and one will stay here in the Atl. club.
Tomorrow evening the floatation will go in and the decks will go on.
Then starts ''Sponson week" LOL
DougMODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
