i have built 4 jae's and spoken with rod on several occasions. he guarantees that it doesnt matter where the prop in relation to the trandsom, it is the height that matters...
JAE Builds
2- 5/16''Originally posted by 6S HYDRO View Posti will be using an adjustable strut, anyone with an adjustable strut like smock's can you please advise me the distance from transom to back of strut please
DougMODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
Sweet!!!Originally posted by 6S HYDRO View Postnope none, thanks. building mine from scratch including machining all the metal hardware
Good luck with the build!!
IMPBA President
IMPBA 19887L CD
NAMBA 1169
Sponsons are done!
Knowing now that a bit of extra weight isn't an issue, I did something a little different with these.
I noticed on mine that the maple dowels for the turn fin had moved just enough to notice it in the finish.
So........... I cut a strip of foam out above the dowels and epoxied a piece of 1/8 X 1/8 " spruce the width of the foam to the top of dowels.
Also, before I epoxied the sides of the sponsons to the foam I drilled a hole in the foam above the brass tubes. After the sides were on I packed epoxy around the brass tubes through the hole to help secure them a bit better.
Next: Sealing begins, build the skis and servo mounts!
Doug
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
Hey Doug, I got a chance to run the JAE hard in some very rough water last weekend just to see how she would handle it. Much rougher than anything I have ever raced in. I had the sponsons bouncing hard in the air when I opened it up all the way and even ended up cartwheeling her. I was using a 40C 5000 pack. Two observations. First, I was using the original hollow booms and didnt break one. I did have the boom clamp tight against the tub without the use of nylon washers. I was wondering if possibly that was the reason my booms didnt break. Also, I have come to notice how flexible the turn fin is. It also has bent slightly along the seam where it screws into the sponsons. I take it a more rigid turn fin is a good thing? I had to scratch going to the Greensboro race this weekend but asked a friend to ask Dick Tyndall (who is known making some nice turn fins) if he has or plans to make a fin for the JAE. Your thoughts..Mike Chirillo
www.capitolrcmodelboats.com
My kit and hardware got shipped today. Should be here by this weekend!
Last edited by BakedMopar; 05-11-2010, 12:37 AM.If all of your wishes are granted, many of your dreams will be destroyed!
i have also cartwheeled mine without breaking the original tubes. windy, rough and 5000mah. no problems yet...see my fleet
: http://forums.offshoreelectrics.com/...hp?albumid=294
I'm glad you decided to pull the trigger!!!Originally posted by BakedMopar View PostMy kit and hardware got shipped today. Should be here by this weekend!
Good luck!
Doug
PS. I don't have a explanation for the tubes guys except we must be faster than you.
We haven't experienced a problem with the turn fin but I've heard that Dick Tyndall is "the man."MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
