The pin holes in my unfinished Raptor Rigger are VERY minor when compaired to my unfinished Phil Thomas SS21 hull.
Raptor Rigger Build
Unfortunately, gelcoat and epoxy don't mix. All the parts are vac-bagged so there isn't much excess resin in there.Originally posted by andym View PostHey Brian, gel coat would be great. Lots of pin holes to fill and paint
Besides, it's lighter if done properly.
The Euro guys (H&M, MHZ etc.) use a type of paint that's not available here.
Leave a comment:
Leave a comment:
Detox,
Use the plate mount for the motor, it really stiffens the tub up. Either notch it from the top to clear wires (like Darin's) or drill a couple holes o clear cooling and wires.
Andy,
Turned out nice, glad you're having fun with it.
Leave a comment:
Detox you are going to love this boat, I am more than happy with mine. The most stable rigger I have built and just as fast as any.
Leave a comment:
I know what you are saying, but I will add a piece of 6mm carbon fiber plate between the servo/reciever compartment and the motor /esc compartment. I think raptor347 has started doing this on his builds, but he uses plywood. Taping down the hatch also adds rigidity.Originally posted by Darin Jordan View PostOnly problem with this is that the motor mount adds rigidity to the center of the hull... I have the plate style, but I trimmed down the top and sides to wires go right over it.
Look closely at picture.Attached Files
Leave a comment:
Only problem with this is that the motor mount adds rigidity to the center of the hull... I have the plate style, but I trimmed down the top and sides to wires go right over it.Originally posted by detox View PostThanks Darin,
I plan on mounting my motor a little different than most. I will use OSE's aluminum mount epoxied to hull floor. That way any wiring or tubing can run along side of tub without mount interfering. I will purchase the "Flat" No bend version, so I can bend it how I want it.
http://www.offshoreelectrics.com/pro...od=ose-drmount
...Attached Files
Leave a comment:
Thanks Darin,
Leave a comment:
That Baby is gonna be NIIIICCCEEEE!
These boats are just SEXY!!
Leave a comment:
Leave a comment:
