Hpr06
  • elvish
    replied
    Ok so to understand what I drew.
    Two carbon half mounts, 2.5mm each, epoxy them together, dremel a path in the middle of them right where the motor will rest, and fit a half cut ring from a water cooling jacket
    Second ring to attach the motor to the carbon half mount
    Leave a comment:
  • malibu1
    replied
    Gerwin,
    I am going to go the home made water pickup route. I have never done it before so I am really scared I am going to messup the bottom of the hull. Your right though, I will have to sand it all anyway. I should put some scratches on the bottom of the hull just so I get over my feers of handling it. I feel like I just got a new car and I am scared to take it out of the garage or get finger prints on it.
    Leave a comment:
  • elvish
    replied
    Ok, for the mount, I haven’t done anything yet, have finished the design on paper, I will post it in 10 mins.
    For the water pickups Gerwin, I think we could put one in front of the other.
    On the 3d pictures the motor is a 1521, the coolers are ose coolers for the 1521, all sizes are original.
    Leave a comment:
  • malibu1
    replied
    Elvish,
    I was wondering what water cooling jackets you are going to use on the motors? From the pictures of the mounts you supplied, it looks like you are going to use similar motor water jackets as me.
    Nice mounts on the rear of the motor! I think I may need to do something similar. Do you think the rear mount will make it hard for getting the motor in and out?
    Leave a comment:
  • Gerwin Brommer
    replied
    Malibu :
    why worries about the bottom of the sponsons being scratched while making the waterpickups in it ???????
    Scratches/damages or not, you have to sand the bottom anyhow.
    Leave a comment:
  • Gerwin Brommer
    replied
    btw : do 2 pickups fit between the axle and the innerside of the sponsons ?????
    Leave a comment:
  • Gerwin Brommer
    replied
    Yoann.
    How to remove a motor from these closed mounts ? ;-)
    Leave a comment:
  • malibu1
    replied
    Elvish,
    I have been looking at those water pickups also. On the rectangular HOTR pickups, it looks like a combination of the right angle tube, and also the shape of the bottom of the oval pickup in the rear is not a "scoop". This none scoop shape would create a cavity that would not drive the water up the tube.
    Looking at pictures, it does look to me like the plastic version does have more of a scoop than the aluminum version. Have not had my hand on them yet so its hard to tell from pictures. I think the smooth transition of the home made pickup is the way to go although it may be harder to install into the hull (for someone who already painted their hull like me )
    Leave a comment:
  • ksm2001
    replied
    Very sweet looking mounts. Keep the pics coming
    Ken
    Leave a comment:
  • elvish
    replied
    [ATTACH]21347[/ATTACH]
    [ATTACH]21348[/ATTACH]
    [ATTACH]21349[/ATTACH]
    Leave a comment:
  • elvish
    replied
    I finished the concept am thinking for the motor support in drawing, and started building it in 3d, if you’re interested I will keep posting updates of it.
    so the basic parts are created, now time for the cutting :)
    Leave a comment:
  • elvish
    replied
    Ok again, this is just my perspective, and I may be wrong
    But let’s understand both designs, I’ve had very little experience on water-cooling in rc boats, but as far as water-cooling, I think I have a great deal of experience.
    I have been water-cooling computers since 2001, when blocks weren’t even available and I had to custom build every part, using car radiators and more...
    Ok enough off topic.
    The reason I mentioned my water-cooling experience is for the simple fact that back in the day, pumps were not that powerful, and to maintain a certain flow in the system required a lot of testing and thinking. One thing we used to avoid was 90 degree angles. Which is basicly the HOTR water pickup?
    Yes it is pretty and yes it saves a lot of work. But is it going to perform like you need?
    when I build a water-cooling project I can always feel the difference by pushing air with my mouth into the system, I feel the resistance, if I change the route of the water-cooling, I feel it getting harder pushing air, or easier.
    And with 90 degree angles, I always experienced a huge difference in flow, as if I had blocked the airway.
    Now if your boat was running like pic 1, it would be ok but the lower the nose is to the water, the greater the angle on you water pickup (HOTR) becomes.
    And that is why I chose the custom tube for my water pickups. And I will put 4 of them. 2 on each side (each motor will have its own; each esc will have its own)
    Elvish, are you going to run the water cooling jackets that are sold here on OSE?
    I misread you talked about OSE water pickups, but the design is the same as the HOTR
    Leave a comment:
  • malibu1
    replied
    Couple more.
    Leave a comment:
  • malibu1
    replied
    Still some glare in these pictures but maybe they show up a little better.
    Leave a comment:
  • malibu1
    replied
    Those all look really good! That TwoFace boat is really something!
    I think you guys are right that I should look at the Evolution 2 or YGE ESC's.
    Leave a comment:
