  • ron1950
    • 3082
    #781
    t 180 with giant power 6000 2s in series neu 1515 2200
      TFL makes mostly D wind motors and the 4D they sell is 2000KV. It's most likely a D wind.
      These are most likely the specs:
      SSS 3674 4 pole 2075kv motor. Come with aluminum billet water cooling jacket. Motor mount not included.
      Type: 3674
      KV: 2075
      Y/D: 4D
      Max Amp (A): 82
      Max Volt (V): 29
      Max Power (W): 2400
      Max RPM: 60K
      Non Load Current (A): 2
      Shaft Diameter (mm): 5
      Motor size diameter x length (mm): 36*74
      Gross weight (g): 320
      Wow, Ray! Thanks! This is great info!
      I want to put one in my MG, was very disappointed with the Aqua Craft 1800KV, brand new and burned during the first run, boat was running a M445, the wires just melted together.
      Anyway, motor is on its way and I hope it will last more than one run!
        Ron,
        nice run! How is the temp on the Neu, mine runs a bit too warm,
        • ron1950
          • 3082
          #784
          temps were barely warm at all water temp is still cool though...
          if the new motor doesent do well try the pb 1800 this is mine with a m445 and a t120 esc https://www.youtube.com/watch?v=Vd3a9y915Vk
            Thanks Ron
            • Jlov
              • Nov 2013
              • 825
              #786
              Looks like it's running tight Ron. Is your strut 1/8" under in that video? Thx Jeff
              • ron1950
                • 3082
                #787
                yes jeff it is
                • Jlov
                  • Nov 2013
                  • 825
                  #788
                  Ok I set mine down to that but still waiting on new Tx to come to be able to run it. I'll post a video when I do.
                    • 7512
                    #789
                    Runs well.
                    • flraptor07
                      • Aug 2013
                      • 2451
                      #790
                      Ron, looks like you got it running real nice, I got mine running pretty decent too. When you get back down here we gotta compare notes..
                      • ron1950
                        • 3082
                        #791
                        ya chris can do....the 6000ma giant power batts are 7 and 3/4 inches long and a few oz's more so it keeps the nose down now
                        • Jlov
                          • Nov 2013
                          • 825
                          #792
                          I just got some 5000mah 4S Gens Ace from Scott. I'm going to run them in parallel for some longer run times.
                            That is what I have now, just curious with a slightly higher kv and long can what it will do.
                              Hey Tim,
                              I think that TFL motor is what come in the stock HK Pursuits at one time.
                              Do you have any pictures you can post of it ?
                              Also what timing are you using on the NEU motor and what motor is it ?
                              • Darin Jordan
                                • 9446
                                #795
                                Hey Guys... It may have already been mentioned, but I haven't read this whole thread...
                                What does the Popeye hull weigh bare?
                                Thanks,
                                Darin E. Jordan - Renton, WA
