    • 5660
    #766
    Jeff, Congrats! Boat runs great! What GPS is that? Is your strut at the highest like Doby suggested?
    • Jlov
      • Nov 2013
      • 825
      #767
      That's my new iPhone in there....guess I didn't learn.... I bought a new Garmin Forerunner201 just can't get it programmed.
      And yes strut up as far as it will go.
      • Jlov
        • Nov 2013
        • 825
        #768
        Just found a problem. Boat flipped at end of last run and one of my antenna tubes popped out and allowed some water in hull. Not much and got most of it out quickly without getting anything wet. But I just was trying to adjust steering and when plugged in lipos all I can control with Tx is servo. Have no motor function at all. Any ideas?
        The batteries got low in my Tx today could that have anything to do with it?
          • 5660
          #769
          Well, yes, if it does not send signal, the fail safe feature kicks in!
          • Jlov
            • Nov 2013
            • 825
            #770
            How do I fix that Tim? Been here messing with it for two hours. Tx is working servo just not motor. I remember with this DX2E I had to hold throttle to full and then plug in batteries or something. Can't get it right now tho....
              • 5660
              #771
              Are you using the MR200? And I assume you changed to fresh batteries for the Tx? I have no experience programing a Swordfish ESC, but most ESC---yes, hold full throtle and then plug in and observe confirmation beeps.
              I didn't quite understand, after you fllipped, you were still ok, later when you are home and repluged the batteries, then there was no motor?
                • 5660
                #772
                Did you try to re-bind , i know channel 1 works, just so you are resetting everything.
                • Jlov
                  • Nov 2013
                  • 825
                  #773
                  No didn't run it again after it flipped. Just went home. Just tonite I realized no motor. Yes MR200. I will try and rebind it now. Thx
                  • Jlov
                    • Nov 2013
                    • 825
                    #774
                    Just was able to rebind it. Still no motor....
                      • 5660
                      #775
                      Any beeps from the ESC?
                      • Jlov
                        • Nov 2013
                        • 825
                        #776
                        No beeps but the green light on ESC stays on for about 10 seconds when I plug it up to lipos.
                          • 5660
                          #777
                          Does anybody know what wind is the TFL 3074 motor? it is sold with the Kintec Popeye, not sure if it is the same motor if one orders directly from TFL.
                          I would like to know, any input is greatly appreciated!
                          • ron1950
                            • 3024
                            #778
                            got a little vid of the popeye...didn't press hard on corners cause I sure didn't want to have to row out to get it if it got air.....still have one more turn fin adjustment on it
                              • 9438
                              #779
                              TFL makes mostly D wind motors and the 4D they sell is 2000KV. It's most likely a D wind.
                              These are most likely the specs:
                              SSS 3674 4 pole 2075kv motor. Come with aluminum billet water cooling jacket. Motor mount not included.
                              Type: 3674
                              KV: 2075
                              Y/D: 4D
                              Max Amp (A): 82
                              Max Volt (V): 29
                              Max Power (W): 2400
                              Max RPM: 60K
                              Non Load Current (A): 2
                              Shaft Diameter (mm): 5
                              Motor size diameter x length (mm): 36*74
                              Gross weight (g): 320
                                • 9438
                                #780
                                What esc you running Ron?
                                Runs nice!
                                https://www.youtube.com/watch?v=zEt8...ature=youtu.be
