Originally posted by SloHD
View Post
That doesn't fix the problem...you would just be running the boat with more "drag" caused by the bent turn fin.Grand River Marine Modellers
SloHD, Its not ideal, basically just means there is a problem else where than rudder alignment.
Jlov- I think you will be pleasantly surprised if you straighten that turn fin, it looks twisted / bent, that will steer the boat for sure. Alligator probably bent it lol.
Originally posted by Jlov View PostThx Doby can def see a difference. Can I straighten mine or just need to order a new one? Page 8 of this thread post 219 is where Chris and Tim are showing the shim that was installed supposedly for this problem.
I would just remove it and straighten it....a shim is not going to fix your bent fin...Grand River Marine Modellers
Your fin is deffinetly bent, you can see it plain as day in the third picture. I'm with Doby, just straighten it and you'll probly solve the problem.Originally posted by Jlov View PostHere you go Doby. Any help would be appreciated. If you go back in this thread there's a bunch of posts about the shim. Supposedly sponson isn't 90* to hull or something. I can offset it by trimming rudder but then boat is fighting itself and I lose some speed.
[ATTACH=CONFIG]112829[/ATTACH][ATTACH=CONFIG]112830[/ATTACH][ATTACH=CONFIG]112831[/ATTACH]
I have a shim and it is to offset the angle of the sponson heel so the turn fin runs parallel to the centerline of the hull. I had it CORRECT and did not have to bent the bracket or the fin. It is no use to bend the fin to compensate for the inadequate off setting in the first place. Your bracket has a longer mounting arm so it was harder for you to shim it correctly, I ditched this bracket for this very reason.
I don't think you have anything to worry about, looks good( your bracket), just straighten the flat part of the fin and see from there how it goes.Too many boats, not enough time...
If you support the inside of the tub wall with aluminum in the area near the tail end of the blade you can rig up a long piece of threaded rod to use as a turn fin tuner. It also acts as a brace to stop flexing and bending of the turn fin.
I have no picture because I haven't done it yet. Others do it, specially for racing so you can dial in the hull so it tracks perfectly straight.
Yes I noticed that in the pic Doby posted of his Popeye. I will definitely do that this coming weekend.
Doby can you post a pic of outside of turn fin so I can see where you put the long support screw thru the outside of the turn fin. It look like it just goes thru the fin itself and not the bracket but hard to see in those two pics. Also what did you use to put the screw thru the hull? Is it just siliconed where support screw goes thru hull? Rubber grommet? Thx Jeff
Here is what's inside....The aluminum plates are held in with my newest favorite adhesive....Marine Goop.Grand River Marine Modellers
Thx Doby. I ordered the thicker 2mm UL-1 fin but will add the fin brace like you have. Question tho,if the long screw is supposed to stop turn fin from flexing wouldn't the screw need to be towards bottom of fin to stop any flexing rather then at top of fin where it meets the turn fin bracket like it is in your pic? Thx Jeff
Mines there to help support the fin mounting bracket, the fin is plenty tough.Grand River Marine Modellers
