The Voracity tuning thread
    Originally posted by montymike View Post
    Important what's the amp draw on each . Could u run any of these on Stock e.s.c.
    I'll put a data logging Esc in it. I'm purposely trying to over prop it to be honest. I'm testing an Esc for someone to test its limits.
    • montymike
      • 786
      #47
      Seaking 180a? What Are temps
      • shua
        • Apr 2015
        • 479
        #48
        I finally maidened mine today.
        Set up is this:
        SeaKing 180
        Hobbywing BEC
        Speed Master billet trim tabs
        Kinetic 4" rudder (for breakaway feature)
        Two part foam and reinforcements Adding 1 lb to the hulls overall weight.
        on 6s
        M545 52mph
        ABC 1815 59.1mph
        • shua
          • Apr 2015
          • 479
          #49
          My temps are low on the SK180
          • montymike
            • 786
            #50
            Set up is this:
            SeaKing 180
            Hobbywing BEC
            on 6s
            M545 52mph
            ABC 1815 59.1mph
            Sweet take much modification?
              I'll find out but I'd bet the 1914 would be safe. It's less prop than the m645
                • 9481
                #52
                Set up is this:
                SeaKing 180
                Hobbywing BEC
                on 6s
                M545 52mph
                ABC 1815 59.1mph
                What timing are you running with that esc /
                thanks
                  Ok, I just did some free mods and just realized the trim tabs were pouting a bit down and one more than the other. Explains why I had to trim the rudder a lot to the left. It's so close to 60 at this point, I'm pretty sure my few mods will put it in the 60's. Here what I did:
                  Sanded the ride area with 400 grit (paint is super super thin so keep that in mind if you do it....you will sand through in a couple of seconds)
                  Sharpened the rudder
                  Sharpened turn fins. One of mine had a slight gouge (my fault I'm sure) so I fixed that.
                  Charging batteries. Stay tuned.
                  • shua
                    • Apr 2015
                    • 479
                    #54
                    thanks
                    15 deg
                      • 9481
                      #55
                      15 deg
                      Thanks
                      • shua
                        • Apr 2015
                        • 479
                        #56
                        Pic of mine with hardware upgrades.
                        • arrover
                          • May 2015
                          • 322
                          #57
                          Look great. Lot of excellent info in this thread already. Did those trim tabs and rudder match up to the stock mounting holes by chance?
                          ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
                          • shua
                            • Apr 2015
                            • 479
                            #58
                            Nope. Not even close. Lol. But at least I was able to hide the original holes easily.
                              This trip was a bust. I ran the wrong prop. Wasn't paying attention. Just had too much going on. Still ran high 50's. Post video later.
                              • arrover
                                • May 2015
                                • 322
                                #60
                                That's kind of what I expected to hear. Really awesome though!
