The Voracity tuning thread
  • Darin Jordan
    • 9446
    #31
    I have pretty much everything that is popular. I used to squeak when it can to buying props but I don't anymore. I'm ordering a couple more today and I has some other abc stuff coming.
    It's time for you to stop dinking around and start getting into organized racing... You've played long enough!
    Darin E. Jordan - Renton, WA
      I know I know. But there's no organized racing anywhere near here. There is a rc car track that dug a lake and was supposed to start racing but that hasn't happened yet.
      • Darin Jordan
        • 9446
        #33
        I know a few people where that's the case... Well... at least you have a decent test pond!
        • arrover
          • May 2015
          • 322
          #34
          I got a CNC 5014 today in the mail and ran it tonight. I don't know a ton about props but I picked it because the total pitch is 2.76 and I wanted to see what a CNC prop was like. Noticeable torque roll when you punch it but seemed to run pretty well and it hit 55.8mph! I pulled it in a bunch to check temps and so I wasn't running hard the entire time straight. On 4S it ran 38.1mph
          batteries - 110ish
          esc - 117-120
          motor - 110
          motor wires/connectors - 165
          battery wires - 105
          ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
            Originally posted by arrover View Post
            I got a CNC 5014 today in the mail and ran it tonight. I don't know a ton about props but I picked it because the total pitch is 2.76 and I wanted to see what a CNC prop was like. Noticeable torque roll when you punch it but seemed to run pretty well and it hit 55.8! I pulled it in a bunch to check temps and so I wasn't running hard the entire time straight.
            batteries - 110ish
            esc - 117-120
            motor - 110
            battery wires - 105
            Not bad for a cnc prop. What battery connectors are you using? What connectors on the motor?
              • 9481
              #36
              batteries - 110ish
              esc - 117-120
              motor - 110
              battery wires - 105
              Very nice man !
              • arrover
                • May 2015
                • 322
                #37
                The motor to ESC connectors are stock (I think they're 5.5mm?). The battery connectors I have changed to 5.5mm bullets. I guess I should have said that this is with the stock motor and ESC.
                • paulfromtulsa
                  • Nov 2013
                  • 211
                  #38
                  batteries - 110ish
                  esc - 117-120
                  motor - 110
                  battery wires - 105
                  Wow that's a huge prop, almost 2 inches in diameter
                  • arrover
                    • May 2015
                    • 322
                    #39
                    Yes, and I think that's why it has more torque roll. I decided to try it because the pitch is 1.4 vs 1.6 on the common Octura props so the total pitch is supposed to be less than the stock prop.
                    • arrover
                      • May 2015
                      • 322
                      #40
                      I spent a couple hours today cleaning up a new M645. It's still not very sharp but I had enough at that point so I went out and ran it. 54.6mph on 6S and 36.8 on 4S (stock ESC and motor). If you punch it from a dead stop, it will spin for about two seconds and then it hooks up and takes off. The delay isn't really a big deal and is kind of fun to watch. It doesn't seem to come into play in turns. I think there's probably more speed in this prop if I had it sharper. That's just a guess though. P.S. I still don't have the option to attach pictures to my posts. Do you have to have a certain post count first?
                      • zooma
                        Local club FE racer
                        • May 2014
                        • 653
                        #41
                        Sorry to hijack thread, but I am attempting to attach a .jpg that I've uploaded from my hard drive.
                        There is an icon on the reply toolbar for inserting an image. You don't have that?
                        Ron - The Villages, FL
                        • arrover
                          • May 2015
                          • 322
                          #42
                          I'm the one that hijacked it. No worries. No, I only have the option to insert an image from a URL. Same thing in advanced reply.
                            Went ran it again today. Made sure batts were fully charged. I made no changes.
                            Abc 1914 58.2mph
                            Abc 1815 56.9mph
                            Abc 1915 53.9mph
                            • zooma
                              Local club FE racer
                              • May 2014
                              • 653
                              #44
                              Interesting. Larger diameter at lower pitch came out ahead. I would have expected the 1815 to be the leader.
                              • montymike
                                • 786
                                #45
                                Important what's the amp draw on each . Could u run any of these on Stock e.s.c.
