The Voracity tuning thread
  • montymike
    • 786
    Yes. Essentially 48mm. I didn't have a finished 1815 (45.7mm) to compare. I suspect it being faster. Find out Saturday.
    This one my bad wrong quote
    • arrover
      • May 2015
      • 322
      Thanks for the info kfxguy! I'm going to restate my numbers in this thread just so the info is here.
      On 6S:
      Stock, untouched prop - 48.7mph
      x645 - 51.0
      x642 - 42.9
      On 4S:
      Stock, untouched prop - 32.8
      x645 - 32.8
      x642 - 30.0
      ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
      • arrover
        • May 2015
        • 322
        It sounds like some of the Voracitys are shipping with slightly incorrect waterline routing. The front waterline on the ESC is very short and is on the verge of being kinked. Also, the water should exit the top of the motor to prevent any air from getting trapped inside the cooling jacket and decreasing the cooling.
        - Take the short hose off the front of the ESC.
        - Remove the medium length hose that exits the ESC and goes to the top of the motor.
        - Disconnect the hose on the other end of the motor (no need to disconnect it from the hull fitting.
        - Take the short hose and connect it from the ESC exit to the bottom motor fitting.
        - Take the medium length hose and put it on the front of the ESC in the same U shape as before.
        - Connect the hose from the hull fitting to the top of the motor.
        Now the water comes out of the top of the motor and exits the boat. The hose lengths fit perfectly, the motor should cool better, and the ESC loop isn't kinked anymore. The new routing is shown below.
          I forgot to add. It seemed very very sensitive to trim tab position. When I had them flat, it would not bounce. And slight angle up and the nose would porpoise. Almost flipped it a couple times.
          I'm having a hard time with this. I want to keep this thing as stock as possible but then I have drawers in my tool box full of motors and escs. I guess I'm gonna have to wait. But I'm getting antsy.
          • montymike
            • 786
            Good info thanks
            • Xtreme Thunder
              • Jan 2014
              • 34
              Subscribed!
              • paulfromtulsa
                • Nov 2013
                • 211
                why do you suspect that the 1815 will be faster than the 1914? its a smaller prop but slightly more pitch is that why? thanks for all the help
                  Yes plus it has more blade rake.
                    Guys go back and read post #9. I edited it with some important info.
                    • paulfromtulsa
                      • Nov 2013
                      • 211
                      what do you think about an octura x648? (with a 180a esc of course) its the same diameter as the 1914 but has a 1.6 pitch. i think that prop might be maxxing out the boat.
                      • Darin Jordan
                        • 9446
                        I'll be interesting in seeing what you guys come up with...
                        Are any of you monitoring the temps on your motor wire plugs??
                        Darin E. Jordan - Renton, WA
                          I checked them last night and iirc they were like 108ish. I did change connectors and the wires are pretty short.
                            Personally I think that's too much prop and I think the abc with less pitch will beat it and pull less amps. But I'll find out. I have one of those too. And a m447 I need to try.
                            • paulfromtulsa
                              • Nov 2013
                              • 211
                              That's great that you have all those props. I will wait for your results before I order one. Thanks
                                I have pretty much everything that is popular. I used to squeak when it can to buying props but I don't anymore. I'm ordering a couple more today and I has some other abc stuff coming.
