The Voracity tuning thread
  • revoltrunner
    • May 2014
    • 646
    #406
    Nope...lol
    the Revolt was my first fe boat after years
    of running nitro boats. The voracity is pretty
    much just a larger Revolt anyway...lol
    • killerbob
      • Jan 2016
      • 25
      #407
      First spin with leopard 4092 1730kv 6s 180a turnigy Esc x542 prop today.
      148A -36500 rpm in water
      Really cold - flakes of thin ice on the water. Lipos 19,6v under max load - used to 21.0 at 147A - guessing the temperature did that. Only logged 58mph, but it really ran low and pushed a lot of water. After trim I'm guessing 70 will be the number at least when the temperature comes up. After the spin - lipos were in the 90'ies. Everything else in the 70'ies. Esc set at 7,5 deg...
      • arrover
        • May 2015
        • 322
        #408
        The prop was a x542?
        ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
        • killerbob
          • Jan 2016
          • 25
          #409
          Yes
          • killerbob
            • Jan 2016
            • 25
            #410
            Arrover - what prop are you using ?? I realize that you and I are running the same setup - except for the prop.
            • arrover
              • May 2015
              • 322
              #411
              I've tested quite a few props on this setup and the results are in this thread. The fastest so far has been an ABC 2214-10-50 at 72.4mph. I did not know that Octura made a x542. It's not on a prop list that I have from them (although it's from Jan 2013) and OSE doesn't seem to carry it. I was just thinking that maybe you meant a x452 or a x548. There is a large difference between a x542 and the big props that I have been trying that's why it was kind of curious to me. Numerically a x542 would be less aggressive than the stock Voracity prop.
              • killerbob
                • Jan 2016
                • 25
                #412
                My bad. X452 it is.... sorry
                • arrover
                  • May 2015
                  • 322
                  #413
                  No problem! Thank you for the running data.
                  • Rafael_Lopez
                    • Jan 2015
                    • 470
                    #414
                    Has anyone done any testing with any 3 blade props? I'm waiting for the X447/3 to come in stock. I have a 440/3 that I may throw in there and raise the timing to see what it does, but I feel it wont have the same effect as the 447/3 will on lower timing. **Stock ESC. Try this at your own risk**
                    Rafael Lopez
                    Product Developer-Pro Boat
                    • Banzee
                      • Mar 2012
                      • 189
                      #415
                      I tryied the x447/3 on mine , On calm water !! Lol ! . the esc and motor just get warm , but my batteries was a little bit warmer than with the stock prop . Sorry i didn't carry my temp gun that time !
                      • Rafael_Lopez
                        • Jan 2015
                        • 470
                        #416
                        Banzee, was this with stock motor and ESC?
                        Rafael Lopez
                          Raphael, I was told that the octura mold for the 447/3 was damaged and they weren't in a hurry to make another one. Someone that called them told me that because he needed a replacement badly. Abc is coming out with a low rake, 48mm 3 blade in the same pitch to fill this void in the market. I should be getting some soon (I hope) and when I do I'll send you one.
                          • Rafael_Lopez
                            • Jan 2015
                            • 470
                            #418
                            Travis, thanks for the heads up. 48/3 may need to be cut, but I doubt the stock ESC would swing it anyways. May be OK with the 160A From the Zelos 48. OR I have a couple HW 180s laying around.
                            Did you get that package I sent you yet?
                            Rafael Lopez
                            • Banzee
                              • Mar 2012
                              • 189
                              #419
                              Yes i got all stock , motor and ESC !!! Didn't check the speed . My batteries are old , about 5 years old , so they didn't push as hard as fresh one ! This summer , i will check for new ones and i will do more test !!
                              • Rafael_Lopez
                                • Jan 2015
                                • 470
                                #420
                                Very Impressive. I bet it was moving huh?
                                Rafael Lopez
