The Voracity tuning thread
  • montymike
    • 786
    #151
    He is not using the stock radio.
    • shua
      • Apr 2015
      • 479
      #152
      These are the Speedmaster Billet trim tabs that I am using. I beleive that they are the same ones KFXGuy is using too.
      http://www.offshoreelectrics.com/pro...d=ros-spdt-502
      And this is the rudder from Kinetic Racing
      • montymike
        • 786
        #153
        What a boat trim tabs...
        • shua
          • Apr 2015
          • 479
          #154
          Check the ose link.
          • montymike
            • 786
            #155
            Sweet thanks...
            • zooma
              Local club FE racer
              • May 2014
              • 653
              #156
              That rudder is the standard TFL Pursuit rudder. As much as I like the kick-back feature, I would rather have a shear bolt than the open slot. I can't seem to get the bolts tight enough to keep the rudder from tilting in rough water at full speed, especially if I get a flip and then keep going. Please post your results.
              Ron - The Villages, FL
              • shua
                • Apr 2015
                • 479
                #157
                So far I have had no issue with unnecessary kickback.
                  • 9481
                  #158
                  Originally posted by arrover View Post
                  I ran an ABC 1915-17-45 this morning. Still stock motor and ESC. Water was glassy and I don't have this prop quite as sharp as it probably should be. A little breeze and a sharper prop might get a little more but anyway..... 57.3mph on 6S and 36.1mph on 4S. This prop has a pretty good amount of slip on acceleration from a stop and in tighter or slow corners. Boat is still handling great though. Lots of fun. Here are some temps. I would run a 2-3 quick passes and then bring it in read temps. I did not run full packs so these temps could go higher.
                  ESC - 126
                  Motor - 105
                  Batts - 95 95
                  ESC caps - 170
                  Motor connectors - 120ish
                  [ATTACH=CONFIG]136818[/ATTACH] [ATTACH=CONFIG]136819[/ATTACH]
                  Love the speeds your getting with that prop, but looks like we could not use that for Q Mono racing
                  curious to see how temps would be for several laps
                  • hobby_man
                    • Sep 2011
                    • 125
                    #159
                    lets talk batteries for this boat. I am running 1 Gens Ace 6s 65-120c 5000 mah with 4 minute run time at full throttle.
                    As you people know boats are lipo battery killers as my stock boat is drawing 112 amps.
                    Gens ace and Pulse batteries have worked the best for me. Anyone running a Pulse 6s lipo in this boat.
                      • 9481
                      #160
                      your average during the run would be about 55-60amps, and that is plenty good
                      I run 65C pulse in my Planes and Helis but think for the money I could get better for cheaper
                      • paulfromtulsa
                        • Nov 2013
                        • 211
                        #161
                        ESC - 126
                        Motor - 105
                        Batts - 95 95
                        ESC caps - 170
                        What does the 45 mean in your prop? I know the 19 is 1.9" the 15 is 1.5pitch, the 17 is the rake but what is the 45? I think this is the prop that i am going to order just want to make sure i order the right one. Thanks
                          Originally posted by montymike View Post
                          Hey, can I get part# for the mods,knowing you had to drill and refill holes.
                          Yea buddy. I used the billet speedmaster trims they sell here. And here's the rudder
                          http://www.offshoreelectrics.com/pro...prod=ose-80050
                          Trim tabs
                          I just put silicon over the holes on the hardware.
                            I've run 91mph with that rudder. Scuff the mounting surface where it clamps.
                            • montymike
                              • 786
                              #164
                              Trim tabs
                              Thanks one stop shopping
                                Yes. I'm about to be working on Steve to start carrying some things that I have to get from kintec so I can just make my build orders from one place.
