Miss Geico Lets see what this thing can do!
  • JPriami
    N4FOX
    • 1711
    #316
    Some miss geico footage from the new rescue & filming rig I built.
      That looks like a great place to run.I was gonna ask about waterborn foliage but I caught the frames of the rescue.I love the water level footage.Thanks for sharing.
      • maxmekker
        • 466
        #318
        Wery nice handy mandy.
        I had the first run since I cracked the front here the other day. Again, one pack ,and all the greez were gone ,and wather comming into the hull from the flex.Also, the servo locked up in the midle of the pond, in left turn position, so I managed to get it to shore by going in circkles about 100 times. I had a towel with me but the sun was down So I did not feel like swiming.I called it the day and whent home to play with my 1/16 Revo instead So I can't really tell if the BP of the bottom had any effeckt, still need to play with lipo placement.I have a poor video, will upload later.
        Drammen rock City
        • wilsta67
          • Feb 2011
          • 203
          #319
          hey JPriami ,
          any chance you can take a few photos of your strut with the boat sitting on a flat surface?
          i just want to see how yours is set up please.
          • JPriami
            N4FOX
            • 1711
            #320
            Originally posted by wilsta67 View Post
            hey JPriami ,
            wilsta67, I can snap some shots of that. But I have slightly adjusted it since my last run and I havent tested this slight adjustment yet. I'll post these in a little bit.
            • JPriami
              N4FOX
              • 1711
              #321
              Here are some pics of it right now. Its setup the same as in the last few vids of it running smoother except for I've added .022 of height above bottom of ride pads. Might be hard to see because my setup surface is clear. But I tried to take a few pics to show it.
              • ecoovert
                • Aug 2011
                • 275
                #322
                Originally posted by lectriglide View Post
                eco - what brand and mah packs are you running to get that 10 minutes? I'd like to increase my runtime since I'm closer to 5 minutes. Hope that motor lasts at 44,000 rpm unloaded. Thanks. OH and a vid is a must!
                I'm using 2x Turnigy 5500mah 30c lipo packs. So far so good with my 2150 kv. motor at 47,730 rpm. My 2,000 kv. motor yields 44,000 rpm.
                • ecoovert
                  • Aug 2011
                  • 275
                  #323
                  Nice looking setup JPriami. Here is a pic of my old Supervee in action. Sorry no onshore vids. yet.
                  What you see at the top is my camera rig.
                  • ecoovert
                    • Aug 2011
                    • 275
                    #324
                    • wilsta67
                      • Feb 2011
                      • 203
                      #325
                      thanks for that JPriami,
                      looking at your strut i now know why mine rides with the nose so far out the water. i haven't tried it lifted up that far!!
                      • JPriami
                        N4FOX
                        • 1711
                        #326
                        Your welcome. Let me know how that works out for you. I ran mine today and it did really well. But I only ran her on 5S then ran the other boat. I'll see what the camera caught when I get home tonight and maybe there will be a video ok enough to post.
                        • wilsta67
                          • Feb 2011
                          • 203
                          #327
                          have you cut some off the back of the strut mount so the prop wont hit?
                          i have lifted the strut on mine like yours and replaced the x442 with a p220 i had to trim a bit of the corner of the strut bracket to give the prop a bit more clearance.
                          wish this rain would bugger off so can go test it.
                          • JPriami
                            N4FOX
                            • 1711
                            #328
                            wilsta67, yes i have cut a good deal off the back of my strut. i also relocated the two holes that mount the offset rudder closer in towards the transom so i can cut the most off I could. has great clearance now plus there is less hanging off the back to get hit by prop spray.
                            Disregard the strut level/position in these pics of mine. just showing what i cut off.
                            Before
                            After
                            here is a little vid from today. Just running 5S in this vid so its in the mid 50's range
                            • 26missgeico
                              • Aug 2011
                              • 63
                              #329
                              what size prop you running in the vid??
                              • HYDROJERRY
                                • Jan 2010
                                • 2709
                                #330
                                Nice one JP,,, i have put a M445 and turnigy 120 in mine and made the parallel 5.5 connectors to run 4x2s 5000 lipos, but we're getting some of this hurricane here so no time to try it out,, bummer!!!!
