Miss Geico Lets see what this thing can do!
  • HYDROJERRY
    • Jan 2010
    • 2709
    #346
    ''O'' my bad..
    • wilsta67
      • Feb 2011
      • 203
      #347
      Originally posted by HYDROJERRY View Post
      Strut looks to high i think,,take off the prop and sit it on the table loosen your strut push the strut down flat on the table with the hull stting flat on the table and tighten it,,,and if your strut wont go that far down grind the hole in the strut to make it long ways up and down then you can adjust it down,,i run mine with my batts level with the front edge of the battery trays ,,hope this helps..
      it was down and it was worse, that's why i moved it up,
      • JPriami
        N4FOX
        • 1711
        #348
        Wilsta. My miss geico didn't run well with a p220 on it. I tried it one time and it didn't seem to run as well as compared to my x642 and p225.
        Not sure if that helps but just saying.
        • wilsta67
          • Feb 2011
          • 203
          #349
          i have a x642 i will try it next.
          • CHIEFY_44
            • Nov 2010
            • 254
            #350
            Try a m445 I run it on mine with just about the same setup
            Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
            • JPriami
              N4FOX
              • 1711
              #351
              Just watched your back view video there 26missgeico. That was neat. Camera does pretty well in low light conditions. Is that a GoPro HD hero or reg GoPro?
              What new esc did you get? What setup are you running now.
              • 26missgeico
                • Aug 2011
                • 63
                #352
                go pro HD going to try to get top speed tonite
                • JPriami
                  N4FOX
                  • 1711
                  #353
                  So 26missgeico,
                  What happened?
                  • wilsta67
                    • Feb 2011
                    • 203
                    #354
                    Originally posted by JPriami View Post
                    So 26missgeico,
                    What happened?
                    lol are you thinking what i am
                    • 26missgeico
                      • Aug 2011
                      • 63
                      #355
                      no you run it for 5 min at a time
                      • Gimp
                        I am the Stig
                        • 547
                        #356
                        J, are you just using the OSE "upgraded" MG flex shaft? How's it holding up?
                        -Fighter Cat Racing-
                        • JPriami
                          N4FOX
                          • 1711
                          #357
                          Yes that's the one. So far so good. The stub is a little shorter so that it creates less resistance in the strut.
                          • Gimp
                            I am the Stig
                            • 547
                            #358
                            Thanks a million. Just wanted to double check before I get a new motor/jacket/flex/coupler.
                            • jasoncyclone
                              • Jun 2011
                              • 495
                              #359
                              I should he getting my cc1515 2200kv motor and turnigy 180 esc soon!!! I can't wait to see what it will do in a MG. Any ideas on the prop I should be running? I was thinking a 642... Maybe a p220???
                              Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
                              • JPriami
                                N4FOX
                                • 1711
                                #360
                                You gonna run 4S or what's the plan?
