*** NEW *** Pro Boat Veles 29 Catamaran
  • MADRCER
    • Feb 2017
    • 765
    #46
    Solid run, good job. The issue with most 4.7mm cables is that they're brazed to the prop shaft which is a fail point, no matter who is making them. It doesn't help that material has to be removed from the cable to stuff it in to the prop shaft. The 3.7mm stock cables in the UL-19 and the Veles 29 is crimped. We've found that the only failure with the mechanical connection is when there is not gap. The cable compresses and pulls itself out of the prop shaft.
    Thanks Rafael! That's good to know. My Veles will be delivered this week and I was having second thoughts on putting one of my good props on it if the cable was a weak link. Can't wait to get it in the water!
    • Rafael_Lopez
      • Jan 2015
      • 470
      #47
      Here is some useful info I posted to FB.
      Rafael Lopez
      Product Developer-Pro Boat
      • vinnyp
        • Mar 2017
        • 283
        #48
        Thanks for the help Raphael.
        • MADRCER
          • Feb 2017
          • 765
          #49
          Wonder how fast this thing will go... Rafael mine didn't come with a manual so I'm going with 6s...
          20170908_155330.jpg20170908_155416.jpg20170908_155601.jpg20170908_155611.jpg20170908_155643.jpg
          • MADRCER
            • Feb 2017
            • 765
            #50
            Comparing it to it"s predecessor..
            • Rafael_Lopez
              • Jan 2015
              • 470
              #51
              If you ever get tired of single drive, the Zelos 36 struts, or similar struts fit on to the back. That was the reason for me doing away with the overhang.
              Amazing how much more speed that hull can handle when you make the hull a true 29 inches on the wet side.
              Make sure to mount your LiPos as far back as possible. She likes them all the way in the back.
              Rafael Lopez
              • Rafael_Lopez
                • Jan 2015
                • 470
                #52
                Oh, and BTW, I see the bag the manual comes in, between the radio box and the packaging. :D
                Rafael Lopez
                • MADRCER
                  • Feb 2017
                  • 765
                  #53
                  Dang I should have paid more attention... Oh well already headed to the lake now. I'm gonna see how well it does with the factory strut suggested setup...Then I'll be putting mine on it, I'm sure.. 75mph OR BUST!!!
                  • MADRCER
                    • Feb 2017
                    • 765
                    #54
                    Veles 29 hits 69mph
                    The Factory setup looked like I was running it in 6 inches of snow with a plow attached at 54mph. Adjustments needed, so I eyeballed the strut the best I could without a flat surface to set it by and topped out at 69mph on the same charge on the first set of batteries. The boat would spin out quite often when you tried to turn quickly. More adjustments needed.
                    • vinnyp
                      • Mar 2017
                      • 283
                      #55
                      Mark,
                      Mine should be here tomorrow. With any luck, the wind will die down some before I try to run it Sunday. Where did you place your batteries? Rafael suggests as far back as possible.
                      • MADRCER
                        • Feb 2017
                        • 765
                        #56
                        Mod number one will be floatation similar to what the Zelos has for the canopy just incase....Here is a photo of the sponsons if anyone is interested. I'm very impressed with the build quality of the hull also! Rafael you have outdone yourself on this one! We now have a mini Zelos!
                        • REDLINE1
                          • 199
                          #57
                          [ATTACH=CONFIG]153734[/ATTACH] [ATTACH=CONFIG]153735[/ATTACH] [ATTACH=CONFIG]153736[/ATTACH]
                          Very nice! Congrats! Interested to see what u can get her up to
                          • MADRCER
                            • Feb 2017
                            • 765
                            #58
                            Veles 29 maiden run @ 69mph
                            Here is the maiden run. I got the spinout problem solved... Overall great build quality on the hull and I'm liking it so far.
                            • MADRCER
                              • Feb 2017
                              • 765
                              #59
                              Originally posted by vinnyp View Post
                              Does OSE have a replacement cable for the Veles? Would the Black Jack or Miss Geico cable fit?
                              Not even close. The stock Geico 29 v3 cable is 12 inches long and the Veles cable is 13 3/16 inches long. The drive dog cut outs are different spaced as well.
                              I also made some good use of some of the packing foam, I put a couple of pieces that were already cut perfectly in the front of the bow. They were like they were made for this area. Only the one large block in the center was there from the factory.
                              • ysae
                                • Aug 2017
                                • 3
                                #60
                                How did u solve the spinout problem
