Mine must be older (2 yrs) and listed item # DYN 4401. I'll try your link and mine doesn't have "tracker" on case either. THX
*** NEW *** Pro Boat Veles 29 Catamaran
Here's my Blackjack withe the Veles motor and a 440/3 prop. I got 64mph
Nice run Mark. Hopefully we can both get to Schaumburg next weekendOriginally posted by REDLINE1 View PostHere's my Blackjack withe the Veles motor and a 440/3 prop. I got 64mph
https://m.youtube.com/watch?v=A6hEOcsjNX0
This thread is sooooo off topic
When is the actual Veles going to be released?Vac-U-Tug Jr (13mph)
Thanks. Holiday weekend extra day to run!Originally posted by fweasel View PostNice run Mark. Hopefully we can both get to Schaumburg next weekend
Ya this veles needs to come out soon. Like to start hearing some feedback
Got my shipping confirmation today!TFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17
Right on VP! At last a boat that doesn't require any upgrades from the box to go fast except maybe the flex cable... I say that because I snapped one of the Factory Geico 29 cables and one Kintec shaft while using the 3831 motor on 6s. So far the OSE cable is holding up well. Does anyone know if the Veles 29 cables are made any stronger than the normal Pro Boat factory cables for the BJ29 and Geico? I heard of a few people breaking on the UL-19 cables also.TFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17
I've been running Jeff's .078 wire drive on my Bj29. No problems so far very good upgradeOriginally posted by MADRCER View PostRight on VP! At last a boat that doesn't require any upgrades from the box to go fast except maybe the flex cable... I say that because I snapped one of the Factory Geico 29 cables and one Kintec shaft while using the 3831 motor on 6s. So far the OSE cable is holding up well. Does anyone know if the Veles 29 cables are made any stronger than the normal Pro Boat factory cables for the BJ29 and Geico? I heard of a few people breaking on the UL-19 cables also.
Other than the Zelos twin, all FG Pro Boats run a 3.7mm cable. Pull out the liner and run a 4.7mm (3/8) if you're worried. As long as you leave a gap between the drive dog and the strut, you shouldn't break a cable. Most cables come apart because people refuse to acknowledge that cable shrinks under load and need space between the dog and the strut.Rafael Lopez
Product Developer-Pro Boat
I have broken two cables, one stock Geico and one being an aftermarket by Kintec in my 3831 equipped Geico 29 with the 5mm gap at the back of the strut as well. The kintec cable appeared to come unsoldered at the prop shaft end. see photo. Rafael check out my run with the 3831 equipped zelos twin at 88mph. Awesome job to Pro Boat on this new motor! https://www.youtube.com/watch?v=SaIkSbd7QGw&t=187sOriginally posted by Rafael_Lopez View PostOther than the Zelos twin, all FG Pro Boats run a 3.7mm cable. Pull out the liner and run a 4.7mm (3/8) if you're worried. As long as you leave a gap between the drive dog and the strut, you shouldn't break a cable. Most cables come apart because people refuse to acknowledge that cable shrinks under load and need space between the dog and the strut.
broken shaft.jpgTFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17
Solid run, good job. The issue with most 4.7mm cables is that they're brazed to the prop shaft which is a fail point, no matter who is making them. It doesn't help that material has to be removed from the cable to stuff it in to the prop shaft. The 3.7mm stock cables in the UL-19 and the Veles 29 is crimped. We've found that the only failure with the mechanical connection is when there is not gap. The cable compresses and pulls itself out of the prop shaft.Originally posted by MADRCER View PostI have broken two cables, one stock Geico and one being an aftermarket by Kintec in my 3831 equipped Geico 29 with the 5mm gap at the back of the strut as well. The kintec cable appeared to come unsoldered at the prop shaft end. see photo. Rafael check out my run with the 3831 equipped zelos twin at 88mph. Awesome job to Pro Boat on this new motor! https://www.youtube.com/watch?v=SaIkSbd7QGw&t=187s
[ATTACH=CONFIG]153694[/ATTACH]Rafael Lopez
