*** NEW *** Pro Boat Veles 29 Catamaran
  • Zondar
    • May 2015
    • 58
    Mine must be older (2 yrs) and listed item # DYN 4401. I'll try your link and mine doesn't have "tracker" on case either. THX
    Traxxas Spartan, RCBB Zonda-R, Promarine MTR, Proboat IMP 31 v3, PB UL-19, Bonzai FE 47 Skater
    • Erroneous
      • Apr 2016
      • 451
      After install try rebooting your computer.
      • REDLINE1
        • 199
        Here's my Blackjack withe the Veles motor and a 440/3 prop. I got 64mph
          • 4335
          https://m.youtube.com/watch?v=A6hEOcsjNX0
          Nice run Mark. Hopefully we can both get to Schaumburg next weekend
          This thread is sooooo off topic
          When is the actual Veles going to be released?
          • REDLINE1
            • 199
            #35
            Thanks. Holiday weekend extra day to run!
            Ya this veles needs to come out soon. Like to start hearing some feedback
            • MADRCER
              • Feb 2017
              • 761
              #36
              Got my shipping confirmation today!
                • 4335
                #37
                'bout time. I saw one on eBay, so I assumed the container finally hit this week.
                • vinnyp
                  • Mar 2017
                  • 283
                  #38
                  Just ordered mine from Horizon. Should be a good boat to mess around with.
                  • MADRCER
                    • Feb 2017
                    • 761
                    #39
                    Right on VP! At last a boat that doesn't require any upgrades from the box to go fast except maybe the flex cable... I say that because I snapped one of the Factory Geico 29 cables and one Kintec shaft while using the 3831 motor on 6s. So far the OSE cable is holding up well. Does anyone know if the Veles 29 cables are made any stronger than the normal Pro Boat factory cables for the BJ29 and Geico? I heard of a few people breaking on the UL-19 cables also.
                    • REDLINE1
                      • 199
                      #40
                      I've been running Jeff's .078 wire drive on my Bj29. No problems so far very good upgrade
                      • vinnyp
                        • Mar 2017
                        • 283
                        #41
                        Does OSE have a replacement cable for the Veles? Would the Black Jack or Miss Geico cable fit?
                          • 4335
                          #42
                          Who knows. Don't have a cable to measure yet... I'm sure they'll add a sku for it once the boat trickles in.
                          • Rafael_Lopez
                            • Jan 2015
                            • 470
                            #43
                            Other than the Zelos twin, all FG Pro Boats run a 3.7mm cable. Pull out the liner and run a 4.7mm (3/8) if you're worried. As long as you leave a gap between the drive dog and the strut, you shouldn't break a cable. Most cables come apart because people refuse to acknowledge that cable shrinks under load and need space between the dog and the strut.
                            Rafael Lopez
                            Product Developer-Pro Boat
                            • MADRCER
                              • Feb 2017
                              • 761
                              #44
                              I have broken two cables, one stock Geico and one being an aftermarket by Kintec in my 3831 equipped Geico 29 with the 5mm gap at the back of the strut as well. The kintec cable appeared to come unsoldered at the prop shaft end. see photo. Rafael check out my run with the 3831 equipped zelos twin at 88mph. Awesome job to Pro Boat on this new motor! https://www.youtube.com/watch?v=SaIkSbd7QGw&t=187s
                              • Rafael_Lopez
                                • Jan 2015
                                • 470
                                #45
                                [ATTACH=CONFIG]153694[/ATTACH]
                                Solid run, good job. The issue with most 4.7mm cables is that they're brazed to the prop shaft which is a fail point, no matter who is making them. It doesn't help that material has to be removed from the cable to stuff it in to the prop shaft. The 3.7mm stock cables in the UL-19 and the Veles 29 is crimped. We've found that the only failure with the mechanical connection is when there is not gap. The cable compresses and pulls itself out of the prop shaft.
                                Rafael Lopez
