Here's pic i shot of my buddy's Gen sittin' on my trailer.........
Genesis cat,,,
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
whow,,nice one i love the realistic pics they make the boats look sweet,,,my father inlaw lives at the lake i got to and has one of those super high dollar camaras that takes like 100 shots super fast and super clear so next time i go out im going to get him to go with me and shoot mine running he did it on my miss elam and they looked super cool but when my old computer got zapped i lost all my pics and info ''DAMN'' ,,,O well got a new one now...
Very nice picture, your Genesis looks like a scale 1 offshore
Replace that long clear tube with a shorter blak neoprene tubing
Thanks Alfa i have cut the antanna tube down by half and plan on changing the cooling tube but i have the clear with ablueish tint tube but wont fit threw the hull where the other one goes threw so ill figure something out..
I changed mine was a pain in the butt. I removed the little metal hose ring held it in my hand started the new hose then stretched the hose to make it smaller while at the same time sliding the hose ring down the house. Took like 5ms just a pain, then I reattached the hose ring and put a dab of ca on the bottom around the ring. Hopefully that makes sense.Originally posted by HYDROJERRY View PostThanks Alfa i have cut the antanna tube down by half and plan on changing the cooling tube but i have the clear with ablueish tint tube but wont fit threw the hull where the other one goes threw so ill figure something out..
Cool i was thinking of removing the original stuff and gluing in a peice of brass tube so i can push on a peice of cooling hose on the top peice running to the rudder then push on the bottom peice from inside the hull, running to the esc that way the brass tube going threw the hull is water tight,,never remove it..
Please could you give me links to the parts ??Originally posted by Diesel6401 View PostOk so I just placed an order for a new flex shaft, a octura short coupler and a new (4-40) servo control rod. Hopefully the bushing I ordered from steve and the drive hardware I just ordered from Kintec arrive very soon.Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
Those photo's are all looking great, looking forward to seeing what the really good camera will turn out, yeah the seaking 180 seems a cool ESC.
Just done the first few runs with mine and the 4074 Leopard 2200Kv going quite nicely.
Thanks for all the good advice i got here.My Boats: SV27 and Genesis Cat
Love to see a vid of yours running on the Leopard motor, was thinking of getting one for mine but kind of pricy so maybe ill wait till i burn my original motor up first..
Here is the bushing I ordered. To use this you have to first remove both the 4mm bushings inside the stock strut. I used a new 3/16 drill bit and drilled dead center of the strut, the drill bit should lock itself inside the bushing then just keep the drill at a low pace and pull out, the bushing should come out with the drill bit. After removing both bushing measure and cut and the speedmaster bushing to the proper size and a dab of ca on the end to hold it in place. Should take about 10-15 minutes. The flexshaft, drive dog & 4-40 servo rod can all be located at Kintec racing.Originally posted by Brushless01 View PostPlease could you give me links to the parts ??
I wish I would have video taped the first run, much better than the run in the youtube clip I have. O well.
Sounds good John and would work but i think its ugly also, was trying to make it look more prolike instead off looking cheap like it does,,i just saw a shinny nipple on Kintec that works like an water outlet but has nipples on both ends, slip it threw the hull and run the nut up on it then connect the two ends off cooling tube to it,,,sounds good to me..Attached Files
Thanks for trying to help John, yeah something with color or just something ill get it figured out soon... Anyone had problems with the flex shredding the heatshrink or if you do like me and use cooling tube it gets torn off kinda strange...
