Glad it worked out for you!
Genesis cat,,,
Yes Yes thanks saved me from ordering from ebay and waiting or buying a new rudder/strut setup,,,,Next question????My clear coat is coming off where i tape the hull can i just score it up with some 400 wet sand paper and reclear it ?????
heres a pic of the factory motor end cap i drilled out to help keep it cool and a pic of the drill bit rudder pin i replaced, cant tell if its factory or not!!!
Good work man nice fix.
I talked a while back about a new motor and ESC i got for mine, here are some pics the work is finally finished, added a 3/16" flex/prop shaft as well.
Test runs this weekend.
My Boats: SV27 and Genesis Cat
Very purdy in there man,, did you drill out the original strut or just get a new one?? Hope to see it wet soon PS be carefull of the tape peeling the clear off the hatch mine has and now im going to have to reclear them hole boat
No i got a new strut, kept all the original stuff so i could put it back if i ever wanted to.
Yeah i know what your saying about the clear coat, this has already happened to mine in one spot along where the back edge of the hatch is.
Didn't know what to do about it so i've put a decal over it to make sure it didn't get any worse.
Looks like i'll have to recoat mine at some point too.My Boats: SV27 and Genesis Cat
I was thinking,,,i use dupli-color crystal clear clear coat out of a quart can think i may try to use a model paint brush on my spots to see if i can just touch it up or have to use my sprayer and spray the hole boat again...
I'm going to leave mine for the time being.
If i start to get it coming off anywhere else i'll recoat it, mines a small spot and covered completely by the decal.
So what do you think just a very light rub down with some fine sandpaper first??
I was going to just go with spray on automotive clear coat.My Boats: SV27 and Genesis Cat
Give it a good light sanding before the clear coat. I've had good luck with Acrylic Lacquer.. paint does not like to stick to smooth surfaces.Originally posted by MarcusOz View PostI'm going to leave mine for the time being.
One thing I do on these clear coated boats is to put a good coat of wax on them before taping. This helps prevent the tape from pulling the paint off.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
Man ive never waxed any of my boats,,maybe i should..
If i do reclear mine i have some 400grit wet sand paper ill use on it and then clear it,,i think the Dupli-color i use is a lacquer but not sure,,but this sucks cuz the original clear is like glass...
I think i'll do what figtercat suggests and give mine a good waxing, makes sense that it will help with the tape adhesion.
I'll leave the decal in place for now as it looks okay in the spot where it is anyway and recoat if i get any more spots of damage.
I'm worried that i won't get as good a finish after i recoat it and if its not absolutely necessary i won't risk it for now.My Boats: SV27 and Genesis Cat
Yeah, it'll never get as good as the original paint.Originally posted by MarcusOz View PostI think i'll do what figtercat suggests and give mine a good waxing, makes sense that it will help with the tape adhesion.
I use a product called "liquid glass". It was originally designed for classic Corvettes. Does a fantastic job and really holds up over time. Used to use it on all of my race glass on the motorcycles and use it on all my painted things now.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
Thanks for that, i'll try and source some locally, if not i'll order some online.
A really good tough finish will just help preserve the finish too as i run mine in saltwater.
Well brackish water anyway on the river near where i live.My Boats: SV27 and Genesis Cat
