TC 31 Brushless Conversion
    • 9479
    #91
    Originally posted by m4a1usr View Post
    Let me surf the category and hook you up. I bought both of mine there and neither was spendy. One was 12 amps for something like $26 and the second was 18 amps but was like $34. Both quality regulated machine tool quality (low ripple/filtered/no noise) and new. If I remember right Andy Kunz works/worked at a place that made something similar. Condor and Power One come to mind for names.
    John
    right on John thank you..
    by the way I am from Seattle, where abouts are you in WA?
    • Jeepers
      • May 2007
      • 1973
      #92
      Originally posted by ozzie-crawl View Post
      having had a 580 6l on 4s imo a 12xl on 6s will be a better setup.
      i personally found the 580 6l to be lacking in torque but others may have had better success.
      still better than the ul-1 motor/esc he was recommended on other forums to run
      yeah a 12XL is better but he was talking about an 11XL at first.
      If I was building this hull on the cheap and ran 6s I would use a 580 9L.
      • dddmx3
        • Mar 2010
        • 233
        #93
        im from vancouver, WA
        Im gettin a IMAX B6 with a 12v 5amp power supply.
        After all is said and done, more is said than done.
        • m4a1usr
          Fast Electric Addict
          • 2032
          #94
          I live in Poulsbo, across the pond from Seattle. Not too many FE maniacs over here! Thats alright. I get the lakes to myself
          I couldnt find any of the name brand switching power supplies for decent prices but one of the better priced ones I found is a 350w unit for under $40. Thats 29 amps at 12v. I use one similar with 2 hyperion eos1210i and the cooling fan never comes on. Even when the garage is hot, like it really gets hot in Washington! Sorry to hijack the thread.
          http://cgi.ebay.com/New-12V-DC-29A-3...item19baaa2615
          John
          Change is the one Constant
            • 9479
            #95
            Originally posted by dddmx3
            lol hahah why would i need a $40 power supply? the one i was lookin at is like $10
            http://cgi.ebay.com/12v-5A-AC-Adapte...item439dff5e6c
            that's only rated at 5A, so if you want to run more than one charger at a time or charge more than 5A you would need a bigger power supply like I do..
              • 7277
              #96
              Plus, if its rated for 5 Amps,,,its probably only good for 3 Amps realistically.
              • dddmx3
                • Mar 2010
                • 233
                #97
                i was thinking of getting a .10 hi tech servo?
                is that to fast?
                • ozzie-crawl
                  • Sep 2008
                  • 2865
                  #98
                  some like fast servos others dont, personally i like high torque but a slower servo so the hull isnt twitchy at high speed.
                  in saying that i always limit the amount of steering i have,then use they exponential on the tx, this allows full turning of the steering wheel from lock to lock but only allows the rudder to move to the limit i want
                  • dddmx3
                    • Mar 2010
                    • 233
                    #99
                    do you i guys think i should run 6s or 4s? Im not so sure about 6s
                    • forescott
                      Hopelessly Addicted to RC
                      • 2686
                      #100
                      I think you will probably be unhappy with the speed on 4s with the 12xl. I would stick with 6s and a smaller prop.
                      • dddmx3
                        • Mar 2010
                        • 233
                        #101
                        ok thanks scott
                        • Flying Scotsman
                          Fast Electric Adict!
                          • 5190
                          #102
                          If you are going to run 6S use extra capacitors for your ETTI esc. and be very cautious on your setup.
                          Douggie
                          • dddmx3
                            • Mar 2010
                            • 233
                            #103
                            Really? Would if I run 5s
                            • Flying Scotsman
                              • 5190
                              #104
                              It all comes down to expectations...speed...run time...$$$$...setup. I do not want to scare you but your proposed and purchased items MAY go boom. Honestly buy an Eagle Tree data logger you will not regret it.
                              Douggie
                              • dddmx3
                                • Mar 2010
                                • 233
                                #105
                                So I should go 4s I mean i don't want any problems!
