TC 31 Brushless Conversion
  • Make-a-Wake
    FE Rules!
    • 6057
    #46
    Quote Ozzie - "we put the motor in a small stepped mono added a extra cell (4s) and a larger than recommended prop"
    Your absolutely correct.....when you set it up wrong its a recipe for disaster................POOF!
    An 11XL when setup with a logical prop choice will not pull more than 100a constant..........more like 50-60.............peak out of the hole amps will spike up there pretty good.
    • ozzie-crawl
      • Sep 2008
      • 2943
      #47
      yep thats rite,just have to take into account new guys not having correct setup IE,over propped,running wet,excessive run time
      • dddmx3
        • Mar 2010
        • 244
        #48
        how do i set it up to not run wet, like it was stated prevously? Put boat on flat surface then the make strut straight?
        After all is said and done, more is said than done.
        • ozzie-crawl
          • Sep 2008
          • 2943
          #49
          when the boat is running at speed it should only have the last few inches of sponsons touching the water,running wet causes the motor to draw more amps causing motor/esc/batts to get to hot.
          strut adjustment and c.o.g are used to get the rite hull attitude.
          • dddmx3
            • Mar 2010
            • 244
            #50
            thank you so much!
            • dddmx3
              • Mar 2010
              • 244
              #51
              What should I set for battery and Cell count? (6s but isnt mine 21v?)
              5 cells LiPo battery (Cutoff Voltage 15.0V)
              6 cells LiPo battery Cutoff Voltage 18.0V)
              7 cells LiPo battery (Cutoff Voltage 21.0V)
              Do I set Braking to Soft, Med, or Hard?
              And What about throttle?
              Also..
              Rotor Rotation, I can leave that at default right?
              Timing options?
              and PWM Options?
              • m4a1usr
                Fast Electric Addict
                • 2036
                #52
                what type of ESC is that..........is it for a Land rig...............fan and all?
                Its one of the Jetti Spin copied ESC's available. The one shown is a Sentillon but they are branded with diffierent names by many sellers. That particular model was one version that did not need a Pistix adapter for use with PG radios. Its been modified with a bunch of soldered on leads for things like an Eagle Tree data logger, UBEC and JST connectors for the exterior on/off switch I like to use, and waterproofed with Silicone Conformal Spray just like the ESC manufacturers do. The fan is a 2" 5v high flow version that keeps the ESC chilly. A cheap Chi ESC that has stayed alive now for over 2 years. But my setup doesnt push it hard either.
                John
                Change is the one Constant
                • video200
                  • 840
                  #53
                  Originally posted by ozzie-crawl View Post
                  "That motor can pull WAY more than 100 amps continuous!"
                  my point is just because the manufacturer may give a max amp rating doesn't meen it wont pull more amps than quoted.
                  most brush less motors will produce way more power and draw way more amps than quoted from manufacturers, they may not do it for long but long enough to kill your esc and batteries along with the motor it self
                  was under the impression that the manufacturer put that as MAX reccomended amp and not what i can actually pull.
                  • ozzie-crawl
                    • Sep 2008
                    • 2943
                    #54
                    thats the way i see it
                    • m4a1usr
                      • 2036
                      #55
                      Carl,
                      Get this motor (see link) and it will be more then you need. Plus its from Steve so you have helped out OSE. And it will swing more prop then you can use. Adapt a motor mount and your set. Plus you saved some decent bux. This would be a good 4S motor in your setup.
                      John
                      http://forums.offshoreelectrics.com/...ad.php?t=13165
                        • 9481
                        #56
                        that would be a crazy motor!
                        • dddmx3
                          • Mar 2010
                          • 244
                          #57
                          check out my tc, just primered getting ready to paint it orange
                          • wakeboardfusion
                            • 514
                            #58
                            Nice lookin good. What type of paint are you using?
                            • dddmx3
                              • Mar 2010
                              • 244
                              #59
                              Acrylic Orange paint
                              BAD NEWS; I painted my boat orange last night, It looked sickk!!!!
                              And then my dad walks in my room steps on my boat and now i have a couple huge cracks in the front of my hull. Im glad i painted it early now i have time to fix the cracks and paint it before my parts come (scheduled to come monday!)
                              • dddmx3
                                • Mar 2010
                                • 244
                                #60
                                Update: Props came. (40mm, 42mm, and the prather)
