TC 31 Brushless Conversion
  • dddmx3
    • Mar 2010
    • 244
    im converting my Pro Boat Thundercat 31 into a brushless monster!
    What i have bought!
    Mount: http://www.offshoreelectrics.com/pro...prod=ose-80210
    Coupler: http://www.offshoreelectrics.com/pro...ct-ocfhe5mm187
    Motor: http://www.offshoreelectrics.com/pro...prod=fei-540XL
    ESC: http://www.offshoreelectrics.com/pro...-race-150-opto
    Cooling: http://www.offshoreelectrics.com/pro...ose-mjacket-XL
    What I have not bought yet:
    LiPos(x2): http://hobbyking.com/hobbycity/store...idProduct=9993
    Charger: Buying IMAX B6 Charger and power supply off ebay
    Heres some of my tc 31. Im painting it orange so excuse all the sanding(:
    After all is said and done, more is said than done.
  • forescott
    Hopelessly Addicted to RC
    • 3009
    aaah! A fellow tc31 builder. You must have seen my build thread. Glad to see someone else interested in the thundercat! Which 580xl motor are you purchasing? I went with the castle motor because I didnt want any overheating issues. Not to say that you will, but I read a couple of other threads with guys who went through several different 580xl motors before finding the right combo. I really like that motor mount though! Good luck with your build!
    • Make-a-Wake
      FE Rules!
      • 6057
      Thats gonna be nice! It looks like a 540XL right? Which motor are you going with.........8XL, 9XL......??
      • ozzie-crawl
        • Sep 2008
        • 2943
        • dddmx3
          • Mar 2010
          • 244
          12xl
          Last edited by dddmx3; 03-08-2010, 11:44 PM. Reason: i said 11xl but i got mixed up i ordered a 12xl
          • Make-a-Wake
            FE Rules!
            • 6057
            OH .....My bad.......i thought you were gonna run 4s??? Duh.............11XL is a great choice for 6s!!
            • ozzie-crawl
              • Sep 2008
              • 2943
              yes it was my suggestions that dddmx3 go with a 11-12xl on 6s.preferably a 12 xl this should also keep amp draw down compared to a 4s setup.
              this should give decent power for a 31" cat not knowing its weight.
              on a other site it was suggested to use a ul-1 motor/esc. imo this would have been insufficient to power such a hull.
              there has been a growing trend on some forums of people giving advice on running 8xls on 6s with turnigy 120a esc,s, thought i would try and save dddmx3 from there stupidity by giving him a reasonably reliable setup for the $$$ he had to spend.
              • ozzie-crawl
                • Sep 2008
                • 2943
                no problem look at they other guys threads and then ask any needed questions, the key to getting decent speed from your boat will be setup.
                you should see 50mph out of that setup with out to much trouble.
                just start with a smaller prop and work your way up .
                • dddmx3
                  • Mar 2010
                  • 244
                  i was thinking of using the normal plastic prop it came with...
                  **for now off coarse, then if everything goes good then get same prop but metal(:
                  • ozzie-crawl
                    • Sep 2008
                    • 2943
                    do you know the dia and pitch ?
                    • dddmx3
                      • Mar 2010
                      • 244
                      no. i would but nvr really thought about this cat. it was sitting in my closet for a while.
                      • wakeboardfusion
                        • 514
                        Looks good! Someday I would like to do one of these conversions. I wish I kept my Shockwave 36.
                        • Flying Scotsman
                          Fast Electric Adict!
                          • 5195
                          Forget any plastic prop, what is the weight of the bare hull, are you looking for speed or more of a sport set up?
                          Douggie
                          • ozzie-crawl
                            • Sep 2008
                            • 2943
                            i will give my experience with plastic props others may have had better luck.
                            i brought a stack of plastic props a few years ago to use as test props,try and get a idea on what prop may suit by using a plastic then once i worked out what was close replace it with a metal one.
                            problem was every plastic prop i tried snapped a blade of every time i got past half throttle, not sure if it was just them being cheap props or the power/rpm of motor.
                            o.s.e sells carbon props that are relatively cheap and don't need sharpening or balancing, mite be worth getting a few
                            • dddmx3
                              • Mar 2010
                              • 244
                              my prop right now
                              check out this prop i wanna buy
                              http://www.offshoreelectrics.com/pro...i-prather-s225
                              i cant weigh it atm i will later
